Where on the X-axis is the Net Force Zero for Charges -5q and +3q?
  • Thread starter Thread starter echau
    Charge
The discussion revolves around a physics problem involving electrostatics, specifically the net force on a charge due to two other charges placed on the x-axis. A charge of -5q is located at x=0 and a charge of +3q at x=10, with the goal of determining where the net force on an additional charge Q would be zero.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the conditions under which the net force on charge Q is zero, questioning the placement of charges and the implications of their magnitudes. Some participants suggest re-evaluating the positions and values of the charges, while others discuss the mathematical relationships involved in calculating the net force.
The conversation includes various interpretations of the problem setup, with some participants expressing confusion over the values and positions of the charges. There is an ongoing exploration of the mathematical relationships, with attempts to derive the position where the net force is zero. Some guidance has been offered regarding the equations involved, but no consensus has been reached on the correct interpretation or solution.
There is mention of a third charge that is not specified, which adds complexity to the problem. Additionally, the units for the positions on the x-axis are not defined, leading to further questions about the interpretation of the values given.
echau
Hi, I'm new here and I was wondering if anyone can help me with a physics problem regarding charge. Any input would be greatly appreciated!
A charge -5q is placed at x=0 and a charge +3q is placed at x=10. Where on the x-axis is the net force on a charge Q zero?
The answer is x=44.4.
Can anyone hlep me solve this? Thanks!
Are you sure that's the right way round? Or that the answer isn't negative? If the greater, positive charge is at x=10, then for any x > 10 there will be a net charge (except at infinity), since the nearest charge is the greatest of the two opposite charges.
Either the two charges need to be swapped around, or the answer is negative, or the answer is between 0 and 10. Double-check.
Welcome to PF, by the way.
I typed it exactly as it is in the book. It really has me confused.
The third charge is not given.
So far it is -5q, +3q, and ?q.
The net force on the charge is zero.
Is there any way to figure out the third charge so that the net force would be zero?
I'm thinking that if I find the third charge, the distance (x) would be no problem.
Hang on... x = 10 what? What are the units of x?
the book just says x=10, as in on the x-axis.
it doesn't give specific units...
the answer is 44.4 (no units) so that means that it's 4.44 times farther from -5q than +3q to -5q (10 units)
You said the charge at x=0 was -q in your OP, not -5q, hence the confusion. I still don't get the value for x as 44.4, though, so I will back down and give way to my betters.
BTW, you shouldn't need to know the third charge, since if the potential at x=44.4 is zero, there will be no net force regardless of the charge. The potential energy of a unit test charge at distance r is given by E = q/(4*pi*e0*r), where e0 is the permitivity of free space. However, I got x=25 so I'm doing something daft.
oops..i didnt realize the typo in the first post. i changed it.
am i supposed to use F=kq1q2/r^2?
Yes, I was being very, very thick. Sorry.
You want to find the value of x at which the force on an arbitrary charge Q is 0.
So, at this point x, the force due to the charge at x=0 is:
F = -5qQ/(4*pi*e0*x^2)
and the force due to the charge at x=10 is:
F = 3qQ/(4*pi*e0*(x-10)^2)
so the total force is:
F = -5qQ/(4*pi*e0*x^2) + 3qQ/(4*pi*e0*(x-10)^2)
and we want F to be 0, so:
3qQ/(4*pi*e0*(x-10)^2) = 5qQ/(4*pi*e0*x^2), so
3x^2 = 5(x-10)^2.
This second part expands to 5x^2 - 100x + 500, so:
3x^2 = 5x^2 - 100x + 500, so
2x^2 - 100r + 500 = 0.
Stick that in the quadratic formula and you have:
x = (-b + root(b^2 - 4ac))/2a
= (100 + root(100^2 - 4*2*500))/4
= 44.4
It's Friday. Hard to think of anything except booze and women.
thank you so much!
You're welcome. You'll notice, of course, I performed two complex mathematical operations on the force due to the charge at x=0, so that it was 5qQ... instead of -5qQ. The first of these two operations is technically known as a 'typo', while the second, more complex one, is called a 'copy and paste error'. However, I've amended it now.
  • · Replies 21 ·
