Deriving Relativistic Mechanics Equation: \gamma
  • Context: Graduate
  • Thread starter Thread starter amcavoy
    Mechanics Relativistic
The discussion centers around the derivation and significance of the equation \(\gamma=\frac{1}{\sqrt{1-\left(\frac{v}{c}\right)^2}}\), which is a key component in the context of relativistic mechanics. Participants explore the origins of this equation, its relationship to the Lorentz transformation, and the historical context surrounding its development.
  • Historical
  • One participant expresses uncertainty about the derivation of \(\gamma\) and seeks resources for better understanding.
  • Another participant explains that \(\gamma\) is derived from the Lorentz transformation equations, providing the equations for reference.
  • It is noted that the Lorentz transformation was developed in response to the Michelson-Morley experiment and the inconsistencies between Maxwell's theory and Galilean mechanics.
  • Several participants share links to resources and derivations of the Lorentz transformation and \(\gamma\), indicating multiple approaches to understanding the concept.
  • One participant points out that \(\gamma\) is a definition rather than an equation, suggesting that it arises in the context of relativistic kinematics and dynamics.
  • Another participant references a previous discussion on the same topic, indicating ongoing interest and exploration of the subject.
Participants do not reach a consensus on a single derivation or explanation for \(\gamma\), as multiple perspectives and resources are presented. The discussion remains open with various interpretations and approaches to the topic.
Some participants mention different historical needs for the Lorentz transformation, highlighting the complexity and multifaceted nature of its development. There are also references to various derivations, suggesting that the understanding of \(\gamma\) may depend on the specific context or approach taken.
amcavoy
It's probably way beyond me at this point, but how was the following equation derived and where did the need come from?
[tex]\gamma=\frac{1}{\sqrt{1-\left(\frac{v}{c}\right)^2}}[/tex]
I was reading a wikipedia article that mentioned it, but that was about it. There wasn't much of an explanation. Does anyone know of a good website that explains this?
Thanks for your help.
In case you don't know what the Lorentz transformation is, it's:
[tex]x'=\frac{x-vt}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
[tex]t'=\frac{t-\frac{v}{c^2}x}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
It is from the Lorentz transformation that we get [tex]\gamma=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}[/tex], which allows the equations to be reduced to:
[tex]x'=\gamma(x-vt)[/tex]
[tex]t'=\gamma(t-\frac{v}{c^2}x)[/tex]
So, the value for [itex]\gamma[/itex] itself comes straight from the Lorentz transformation. There are actually quite a few ways to derive the Lorentz transformation. Einstein was the one who found the most simple and elegant way of deriving the Lorentz tranformation, showing that the equations come straight from two simple postulates: (1) All inertial frames are equivalent for the description of the laws of nature (the principle of relativity). (2) The speed of light is a constant in all inertial reference frames. A simple derivation, from Einstein himself, can be found here:
http://www.bartleby.com/173/a1.html
Just like there are multiple ways to derive the Lorentz transformation, which were realized about the same time, there were also multiple needs. The original need, that Lorentz came up with the Lorentz transformation for, was the Michelson-Morely experiment, which seemed to show that the speed of light is always the same no matter how fast you are moving. Lorentz suggested that maybe lengths contract in repsonse to motion through the ether, so that could be why the speed of light always appears the same. However, Einstein arrived at the Lorentz transformation from a different angle. He realized that Maxwell's theory of electromagnetism and Galilean mechanics didn't fit well together. Einstein didn't think it made sense for Maxwell's theory to be applied to any particular ether reference frame, so he sought the replacement of Galilean mechanics that would allow it to be applied to all reference frames, and ended up with the same equations Lorentz had found.
That's really interesting. I guess I will get to study that further in future physics classes. Thanks a lot for the long post and information, it really helped.
Alex
apmcavoy said:
How was the following equation derived and where did the need come from?
The simplest derivation is given here:
http://www.pa.msu.edu/courses/2000spring/PHY232/lectures/relativity/dilation.html
The most elegant derivation follows these lines:
http://www.everythingimportant.org/relativity/
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=AJPIAS000043000005000434000001
http://arxiv.org/PS_cache/physics/pdf/0302/0302045.pdf
That is not exactly an equation. That is a definition of the symbol [itex]\gamma[/itex]. To see where this comes up you can see the following
Relativistic Kinematics -
http://www.geocities.com/physics_world/sr/light_clock.htm
http://www.geocities.com/physics_world/sr/lorentz_contraction.htm
http://www.geocities.com/physics_world/sr/lorentz_trans.htm
Relativistic Dynamics -
http://www.geocities.com/physics_world/sr/inertial_mass.htm
Pete
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 31 ·
