Calculating Car's Acceleration in Circular Motion
The problem involves a car traveling in a circular path while maintaining a uniform speed. The discussion focuses on calculating the acceleration of the car at a specific point during its turn and understanding the difference between instantaneous and average acceleration over a given time interval.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between velocity and acceleration in circular motion, questioning how to express acceleration in vector form. There are discussions about the nature of average acceleration versus instantaneous acceleration and the role of centripetal acceleration.
The discussion is ongoing, with participants offering hints and guidance on how to approach the problem. Some have provided insights into the definitions and properties of acceleration in circular motion, while others express confusion about the concepts involved.
Participants are grappling with the implications of constant speed versus changing velocity, and there is mention of the need to consider both x and y components of acceleration. The original poster seeks clarification on whether calculus is necessary for the problem.
tubworld
A car initially traveling eastward turns north by traveling in a circular path at uniform speed. The length of the arc ABC is s metres, and the car completes the turn in t seconds.
What is the acceleration when the car is at B located at an angle of r degrees? Express your answer in terms of the unit vectors x and y component?
Determine its average acceleration during the t seconds interval.
Any hints to do this? What is the difference in ans between the 2? is there a need for calculus?
I've completed your problem.
For the first part, draw a diagram of what you think is happening and come up with a formula for the velocity (velocity not speed) of the car at any time in terms of the parameters you have. This is your starting point.
For the second part, a general hint is that any average is just the difference between the final situation and the initial situation divided by time (resolve).
I hope that I haven't given too much of a help but enough of a help to guide you to the method of finding solution. It was a fun problem I thought.
but for the second pt, the final acceleration is = to the initial acceleration since the linear speed is constant and the only acceleration is the cetripetal acceleration.As such, it's tentamount to saying that the average acceleration is 0.
acceleration has both a direction and a magnitude, so is a vector.
You have to find the vector average of the acceleration.
Defn: (average) accln is the (vector) change in velocity over time.
Serioulsy, I am still confused. The velocity of the car is changing at all instances but its speed is kept constant. As such, I understand that there is acceleration but its due to a change in direction and not magnitude. So how do I express this?
You need to review the basic facts of circular motion. When something travels in a circle at uniform speed, its acceleration is towards the center. Accordingly, this is called centripetal acceleration. (Look it up!)
Consider the x and y directions of (constant) acceleration* separately and then combine them.
* The acceleration being the one that will transform your initial velocity to your final velocity in the given time.
