Why is a neutral axis necessary in beam theory?
  • Context: Undergrad
  • Thread starter Thread starter chandran
    Axis Beam
The discussion revolves around the concept of the neutral axis in beam theory, particularly its necessity and behavior during bending. Participants explore the implications of the neutral axis in relation to compressive and tensile forces within a beam, as well as its geometric properties during deformation.
  • Some participants explain that the neutral axis represents the transition between compressive and tensile forces in a beam, where the force is zero.
  • One participant questions whether the neutral axis remains horizontal during bending, expressing difficulty in visualizing its behavior.
  • Another participant asserts that the neutral surface remains constant with respect to the beam's geometry, suggesting a visual analogy of a grid painted on the beam that deforms with it.
  • It is noted that as the beam bends, the top fiber shortens due to compression while the bottom fiber elongates due to tension, with the neutral axis being a fiber that does not change in length despite the curvature.
Participants express varying levels of understanding regarding the behavior of the neutral axis, with some agreeing on its role in force transition while others remain uncertain about its geometric properties during bending. The discussion does not reach a consensus on the visualization of the neutral axis.
Participants highlight the need for further clarification on the neutral axis's behavior, indicating potential limitations in their understanding of the underlying mechanics and geometry involved in beam bending.
chandran
in beam theory it is mentioned that there should be a neutral axis which remains
constant in length before and after bending. Why should there be a neutral axis
like this?
In a beam, the neutral axis is the transition between compressive and tensile forces.
Push down on a beam and the bottom of the beam (e.g. flange) is 'stretched'. The top of the beam is constrained by the material below (the height or cross-sectional thickness), and so the top of the beam is in compression.
Somewhere between the tensile force and the compressive force, continuity requires the force to be zero, or neutral, neither compressive nor tensile.
Hi,
Does this mean that the neutral axis stays horizontal?
I understand that there must be a fiber somewhere in between that is neither subject to compression nor tension, but I cannot visualize it. I do not visualize a fiber, somewhere in the middle, staying horizontal when the beam is bent.
It might be a dome question, but could someone explain me more about this or suggest any material that I could review to understand this.
Thank you,
if you divide the beam into fibers then the top fiber becomes shorter with compression and the bottom most fiber elongates with tension(this is for the case where the beam bends such that is smiling at you). Neutral axis/surface is a just a fiber that lies between these the top and bottom and does not change in length although it is curved
  • · Replies 22 ·
  • · Replies 32 ·
