Do you know how to handle pressure when it hits?
  • Thread starter Thread starter Ivan Seeking
    Pressure
The discussion revolves around participants' experiences and reactions to pressure in various situations, particularly in work-related contexts. It explores personal coping mechanisms, emotional responses, and the impact of pressure on performance and relationships.
  • Some participants describe feeling overwhelmed by pressure, particularly when facing tight deadlines or complex projects, leading to physical symptoms like muscle tension and panic.
  • Others express that they perform well under pressure, finding it motivating, especially when the expectations are low or unclear.
  • One participant mentions a tendency to withdraw from social interactions when under stress, which they recognize as a learned response to avoid snapping at others.
  • Some participants note that while they may handle high-pressure situations well, the anticipation and preparation for these situations can be draining.
  • A few comments suggest that reactions to pressure can lead to misunderstandings or negative perceptions from others, particularly if one does not visibly respond to stress.
  • There are humorous references to external pressures, including a mention of a public figure's reaction to workplace stress, illustrating the varied contexts in which pressure is experienced.
Participants express a range of views on pressure, with some finding it beneficial and others struggling with it. There is no consensus on the best way to handle pressure, as experiences and coping strategies vary widely.
Some participants' responses are influenced by specific work environments and personal histories, which may not be universally applicable. The discussion reflects a variety of emotional and psychological responses to pressure without resolving the complexities involved.
Ivan Seeking
Staff Emeritus
Pressure pressure pressure!
When do you feel it? How do you react?
I do extremely well in certain situations, such as when troubleshooting a system failure or problem, but the slow boil as a work deadline for programming and integration [office work] approaches can be gut wrenching. Often I am handed what is known in the industry as a fuster cluck [sort of] and am often left holding the bag for every error that has even been made by anyone one of ten or twenty people, or more, anytime over the last days, to years. Sometimes the inability to connect the dots on a project due, late on a Sunday night, can just about cause me to stroke out. Last night this happened - it got away from me a little. Before I got ahold of my emotions, I could feel muscles tightening as a sense of panic started setting in. Before long it felt like my head might just explode at any moment, which can be quite messy, but when I felt the pounding in the front of my head, something that I have learned to recognize as a signal that things are getting out of control, I forced myself to back off the juice and calm down.
In this case, as it turned out, I cried uncle and started an email explaining that I was not ready [I knew that they weren't yet either but I was supposed to be done] and I began to relax as my list of problems and discontinuities grew larger and larger with every passing moment. This morning, having read my email, everyone is apologizing to me for all of the screw-ups and bad information. Thank God! As a private consultant and programmer, my liability can be pretty high on big projects.
Anyway, that's my weak spot - the slow boil. It can definitely get the best of me at times.
I respond quite badly to pressure. I should probably say no more.
I don't like it, but it seems I need it to get something done...
I like pressure. About the only thing I don't like is waiting on somebody else to give you something you critically need in order to meet your own deadline. But, once it's in, I can work in a pretty good mood even if it's put me in a time crunch.
I especially like the jobs where nobody even knows what questions to ask, let alone how to get an acceptable result. In a way, there's less pressure when any result short of disaster is considered good.
Stop fussing Ivan i know you are the best in your field, just chill out, and cuddle
up to Tsu, now that is better is it not??
But keep your hands where we can see them, this is a familly site!
That's where I run into trouble too, when more and more keeps getting piled on at a faster rate than I can complete projects. My general tendency doesn't help, because I start to just withdraw from wanting to be around people when that happens, but that's when I most need to have someone around who I can vent to so I don't completely explode. But, withdrawing is sort of a learned response...I used to just get insufferably b****y and snapped at everyone over every little thing when I was under a lot of pressure. I've learned not to snap at them, but that's easiest done if I'm just not around people. But that only happens under the most extreme stress (like last month just before I moved...I thought I was going to implode from everything I had weighing on me that needed to get done before moving...I have been sleeping VERY well ever since moving into the new place because I'm still catching up on all those sleepless nights just before I moved when the lists of things that still needed to be completed were racing through my mind every night).
Those two middle paragraphs pretty much describe situations in which I sometimes find myself. In the past, it was usually a senior manager promising the impossible to a client, and then me figuring out how to do it. :biggrin: And sometimes it was me taking a really screwed up project and cleaning up the mess.
Fuster cluck, eh? I guess that's putting it politely. :biggrin:
I can thrive on pressure, if I don't find myself taking a wrong turn and hitting a bumpy road or dead end.
I do find myself in a slow boil sometimes. Then I have to walk away, forget about it, and clear my mind.
People get mad at me or suspicious of me because I don't respond to pressure situations.
Time will tell :rolleyes:
I would expect so. Most people want to know that you give a damn.
Hello! I am a serial killer! :smile:
I'm usually fine in 'high-pressure' situations; job interviews, taking tests, super busy at work, etc. It's the preparation for and worrying about them that drains me. That is, I feel the pressure before and/or after I perform, but I'm cool while performing. I need to get my hands on some of those chill pills people are always talking about. Anyone 'know somebody'? :wink:
I thought Steve Balmer was posting on GD. Steve is under a lot of pressure because his employees are going to Google.
http://news.com.com/Court+docs+Ballmer+vowed+to+kill+Google/2100-1014_3-5846243.html?tag=nefd.top
"In a sworn statement made public Friday, Mark Lucovsky, another Microsoft senior engineer who left for Google in November 2004, recounted Ballmer's angry reaction when Lucovsky told Ballmer he was going to work for the search engine company.
"At some point in the conversation, Mr. Ballmer said: 'Just tell me it's not Google,'" Lucovosky said in his statement. Lucovosky replied that he was joining Google.
"At that point, Mr. Ballmer picked up a chair and threw it across the room hitting a table in his office," Lucovosky recounted, adding that Ballmer then launched into a tirade about Google CEO Eric Schmidt. "I'm going to f***ing bury that guy, I have done it before, and I will do it again. I'm going to f***ing kill Google.""
His new war cry is: Developers, Developers, Developers...please come back.
It has nothing to do with caring. Most of the typical responses to pressure are not helpful, so it is better to not have them. That's kinda the point of military basic training - to condition you against losing your cool and becoming useless in a pressure situation. Ie, while a little turbulence turns most people in an airliner to blubber, the pilots are up front, cool as a cucumber. It isn't because they don't care, its because they are professionals.
These days, most of the pressure situations I get into involve being out-of-my-leage in meetings. My boss has a tendency throw me in the water to see if I can swim. Not responding to the pressure equals professionalism and respect. The time when people get mad about it or afraid of the situations is when they lose their cool, and I don't.
Oh, I see. You're using "responding" differently than I would (and I suspect Ivan does based on his reaction). Losing your cool, panicking, bursting into tears, etc., is responding poorly to pressure (or just plain crumbling under pressure), and is completely unhelpful. Keeping focused on task, not letting your emotions interfere with your thinking, providing an outward appearance of calm to reassure others even if your gut is crawling, etc, is a good response to pressure. You're still responding to the situation and getting things done.
Or a postal worker. :smile:
Early on, the preparation is the only thing that ever got me through pressure situations. As long as I have something else to try, I don't get too intimidated. My worst fear was hitting a dead end where I couldn't think of anything to do.
I think I'm naturally averse to pressure and to any kind of risk in general (risk of failure and humiliation included). I think it took both pressure and building a record of success to push me closer to working at my full potential. I would say I'm still pretty averse to risk, but it's more that I focus on making darn sure the critical parts don't fail than being afraid of them.
Perhaps - I tend to think that there is no such thing as a positive response to pressure. Ivan's post was pretty much entirely about negative responses he had to pressure. (edit: caveat) ie:
But that's just doing your job, whether pressure is involved or not. The big issue with pressure is if it changes how you do your job. Ie if a meeting is going well and suddenly someone starts raising their voice, you continue to focus on the task by not responding to the pressure - by not raising your voice in response - by continuing to do what you were doing before. When pressure starts to build and your blood pressure doesn't rise, that's a non-response.
In any case, I understand what you mean now, even if we are talking about two different things.
(edit:caveat) Stress triggers certain biological responses that can help deal with danger (you're the biologist though - I'm sure you know more about the physical responses than I do). Adrenaline, for example. However, I don't think that those biological responses are typically helpful in the type of stress that most humans see. I see shaky, tingling hands (adrenaline shock?) and a knot in your throat as a purely physical/biological response that for people in white-collar stress situations are utterly useless and even harmful. Now if you're a fire fighter or a soldier, those physical responses to physical danger could be useful - but even then, our best weapon is our brains and those physical responses intefere with its operation. That's why the the military doesn't teach people to go berserk in danger situations, it teaches them to remain calm.
Yeah, the whole "fight or flight" response doesn't work so well when you're sitting in an office with the work piling higher and higher and there is no one to fight and nowhere to flee. And, I do think it's a complete over-reaction to situations like that. I have relatives like that (we probably all do...or know someone who fits the description), who are CONSTANTLY complaining about how stressful this or that is, and I have no sympathy. Aw, gee, you're busy at work, isn't that why they call it "work" and why you get paid to do it? :biggrin:
I can usually trace most of my reaction to stress to the accompanying sleep deprivation. It probably isn't correct to call it stress, I should just call it the sleep deprivation that it is. That's the irritability and withdrawing from being around people part.
But, then the adrenaline rush sometimes is helpful when there is a physical component like that (no sleep for 3 days to meet a critical deadline), because it just keeps you going.
Beyond that issue, when I really get stressed to the point where I feel like I am on the verge of "losing it" is when too many things are outside of my control. I can cope very well if I am responsible for things and if something doesn't go well, I have the ability to fix it. It's when I'm at a point where someone else takes over and I just have to sit and wait for them to do their part that I go nuts. I don't have an easy time trusting other people to do their job when it's down to the wire and their job affects my job, especially if I don't supervise them, so have no authority to kick their butt into gear for them. I'm not very good at just sitting back and saying, "It's out of my hands now," because I still feel personally responsible for a project I'm doing, even if it's someone else's screw up.
I said that people want to know that you give a damn - its a matter of perception. That is why they get suspicious of you, as you said, which contradicts your last statement.
I probably should have been a little clearer about that: no one has ever accused me of not caring in a professional situation that was stressful - I've only ever been complimented for my professionalism. I only hear suspicion (perhaps a poor word choice: incredulity may be more accurate) from a couple of my female friends, who apparently would like to see me come unglued every now and then in personally stressful situations. Ie, in a particularly uncomfortable car ride on a road trip, they didn't believe me when I said I was fine. They tease me about being unemotional, but they do respect it as well.
Also, one particular friend and I used to debate about fighting in relationships - she used to say that it was a healthy thing to let out your frustrations by screaming at each other every now and then. Now she's married and she and her husband fight physically on a nearly daily basis (and she's a lot smaller than he is).
Its two separate parts of the same personality trait.
Arguing ocassionally is healthy, fighting isn't. As long as two people still remain individuals, they're bound to disagree about things and argue once in a while. It would be unhealthy to not say anything and just let it fester. But, that's very different from actually fighting, in which case it's attacking each other rather than arguing over the issue that's the problem that needs fixing. It's not really much different than the rules around here...attack the argument not the person.
If you're fine, are you sure you're under pressure? :rolleyes:
  • · Replies 27 ·
  • · Replies 25 ·
