Simple Optics: Image Formed By Two 15cm Lenses
  • Thread starter Thread starter beethoven'smahomeboy
    Optics
The discussion centers on the formation of an image by two converging lenses, each with a focal length of 15 cm. When an object is placed 15 cm from the first lens, the thin-lens equation indicates that the image formed by the first lens is at infinity. The second lens, positioned 20 cm from the first, receives parallel light rays from the first lens, resulting in the formation of an image at its focal point. Consequently, the final image is located at the second lens's focal point, maintaining the same size as the original object.
  • Understanding of the thin-lens equation
  • Knowledge of converging lens properties
  • Familiarity with focal length concepts
  • Basic principles of light behavior through lenses
  • Study the thin-lens equation in detail
  • Explore the behavior of light rays through multiple lens systems
  • Learn about image formation in optical systems
  • Investigate practical applications of lens combinations in optics
Students of optics, physics educators, and anyone interested in understanding image formation through lens systems.
An object is 15 cm from a converging lens of focal length 15 cm. A second positive lens of focal length 15 cm is 20 cm from the first lens. Where is the final image (s)?
Since 1/15+1/s=1/15 by the thin-lens equation, is there an image formed?
beethoven'smahomeboy,
If light from a far away object (parallel light rays) falls on a convex lens it will form an image of the object in it's focal plane (that is how the focal length of such a lens is defined). If an object is placed at the focus of a lens we get conversely that it forms an image of the object at infinity (very far away) again with parallel light rays leaving the lens. Your equation above get 1/s as zero, which implies that the image is at infinity. For the second lens the light looks like it is coming from an far away object (that is the rays are traveling parallel to each other after leaving the first lens). This means that the second lens will form an image of the original object at it's second focus. The distance between the two lenses are irrelevant. The object is therefore mapped from the focal point of the first lens to that of the second lens. Since both lenses have the same focal length the final image will be the same size as the original.
