Tangent Properties Symmetry, domain, asymptotes, zeroes
The discussion revolves around the properties of the tangent function, specifically analyzing the function y = -2tan(3x + π) + 3. Participants are tasked with determining the period, y-intercept, range, domain, symmetry, vertical asymptotes, and zeros of the function.
  • The original poster attempts to identify the domain and vertical asymptotes but expresses confusion about how to interpret the results from their graphing calculator. They also question how to determine symmetry and zeros of the function.
  • Some participants suggest looking at the basic properties of the tangent function and its graph to clarify the domain and vertical asymptotes.
  • Others raise the importance of considering the argument of the tangent function in radians and how that affects the calculations.
Participants are actively engaging with the original poster's questions, providing guidance on how to approach the problem without giving direct answers. There is an acknowledgment of the need for the original poster to demonstrate effort in understanding the concepts involved.
There is a mention of the original poster's struggle with interpreting results from their calculator and the need to work in radians rather than degrees. The discussion also highlights the relationship between vertical asymptotes and the domain of the function.
aisha
[tex]y=-2\tan (3x+\pi) +3[/tex]
state the following
period = [tex]\frac {\pi} {3}[/tex]
y-intercept=3
Range = {y: yER}
Domain= {x: ?}
Symmetry?
Vertical Asymptotes?
Zeros?
Can someone please tell me how to figure out what is left there are so many zeroes and i can't read them off of my graphing calculator and same with vertical asymptotes aren't zeroes and this the same thing? I'm a little confused can someone please help me out? I am not sure how to find symmetry either .
https://www.physicsforums.com/showthread.php?t=28
Peope here won't do your homework for you. If you can prove to someone you gave the problem decent effort before coming here for help then maybe someone will POINT YOU IN THE RIGHT DIRECTION but not solve it for you.
That's just a little bit harsh- The original post DID include answers to the the first part of the problem- period, y-intercept, range.
Aisha- the "domain" is the set of all x values for which the function CAN be calculated. The basic function here is tan(x). For what values of x is it NOT possible for find tan(x)? Looking at a graph of y= tan(x) in your textbook might help you see that.
Symmetry should be obvious from a graph- or from the fact that tan(-x)= ?
Vertical asymptotes- closely associated with the problem of finding the domain! Look at graph- perhaps using a large "window".
zeros- where is [tex]y=-2\tan (3x+\pi) +3= 0[/tex]? Solve the equation!
ok i still don't think I get symmetry but for the range I've got
{x: x cannot = -90,90,270,...,XER}
this is from tan(theta) not from the equation I wrote in the first post.
If i look at that equation on my graphing calculator i get
{x: x cannot= 0.47, 1.53, -3.76, -4.80.. XER}
the vertical asymptotes will be the same numbers I assume
Please help me out a little more thanks
im not sure how to solve the equation equal to zero
Aisha- did you notice that [itex]\pi[/tex] in your function? When trig functions are used as <b>functions</b>, rather than to solve problems about right triangles, the argument is <b>always</b> in radians, not degrees! <br /> <br /> tan(x) is not defined (and so the domain does not include) [itex]\frac{\pi}{2}[/tex], [itex]-\frac{\pi}{2}[/itex], or generally any odd multiple of [itex]\frac{\pi}{2}[/tex]- that is, any number that can be written [itex](2n+1)\frac{\pi}{2}[/itex] where n represents any integer.<br /> However, your function involves [itex]tan(3x+\pi)[/tex]. For what values of x is [itex]3x+\pi= (2n+1)\frac{\pi}{2}[/itex]?<br /> <br /> Of course, you can solve [itex]-2\tan (3x+\pi) +3 = 0[/itex]!<br /> That's the same as saying [itex]tan(3x+\pi)= \frac{3}{2}[/itex].<br /> Can you find [itex]\theta[/itex] so that [itex]tan(\theta)= \frac{3}{2}[/itex]?<br /> You might need to use a calculator for that. Be sure to put it in radian mode!<br /> <br /> Once you found that [itex]\theta[/itex], finish by finding x so that [tex]3x+\pi= \theta[/tex][/itex][tex].[/tex][/itex][/itex][/itex]
sry when I posted that I was having a bad day... sry to take it out on all of you guys
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 17 ·
15K
  • · Replies 53 ·
