Particles like neutrino have zero mass and zero charge
The discussion revolves around the properties of particles like neutrinos, specifically their mass, charge, and spin. Participants explore the implications of these properties, the nature of spin, and the differences between neutrinos and antineutrinos. The conversation includes theoretical considerations and interpretations related to particle physics.
  • Some participants question how a particle with zero mass can possess spin, and whether it is appropriate to classify such an entity as a particle.
  • One participant clarifies that spin is a property of particles, similar to charge, and does not imply actual spinning motion.
  • Another participant notes that spin is relevant for determining the behavior of particles in magnetic fields, with specific reference to the two possible spin states.
  • A claim is made that recent developments suggest neutrinos may have a small mass, which could affect certain physical equations, such as those involving beta decay.
  • There is a discussion about the spin values of neutrinos and antineutrinos, with some participants asserting that both can have the same spin values of +1/2 and -1/2.
  • One participant expresses confusion about the nature of the spin value of 1/2, suggesting it might be a probabilistic measure, which is challenged by others who clarify that it is a fixed quantum number.
  • Participants discuss the conservation of lepton charge and the implications of measuring spin along different axes, emphasizing the abstract nature of spin in quantum mechanics.
  • References to Dirac spinors and related papers are introduced, indicating a desire for deeper exploration of the topic.
Participants express differing views on the nature of neutrinos, their mass, and the interpretation of spin. There is no consensus on whether neutrinos are massless or have a small mass, nor on the implications of spin values.
Some discussions involve assumptions about the definitions of mass and spin, and the implications of these properties in particle interactions remain unresolved.
This discussion may be of interest to those studying particle physics, quantum mechanics, and the properties of fundamental particles, as well as individuals seeking clarification on the concepts of mass, charge, and spin in theoretical contexts.
kiru
Hi friends,
I have read that particles like neutrino have zero mass and zero charge.Yet it has the spin value (1/2).How it is possible?It is difficult even to imagine an item of zero mass spinning.Is it right to call an item of zero mass as a particle?If yes,What is a particle ?Can someone help me in knowing what is spin?And how it is determined?Why it is always in multiples of (1/2)
As i understand it, spin doensn't mean the particle is spinning. Its just a property attributed to it like charge. Quarks have "colours" which obviuosly doensn't mean they actually have coolur. Its just a property
Spin has almost nothing to do with the classical angular momentum. Spin is a property you need to calculate the direction in which the correspondanding particle will go if there is an external magnetic field. (There are two spin values, spin up and down and thus two direction a particle can go by applying a magnetic field).
Your book (or whatever) is out of date. In the past few years most particle physicists have come to believe that neutrinos actually do have a small mass, revealed by the phenomenon of "neutrino oscillations."
Of course I know little that the the value (1/2) is due to the probability value.If you say that neutrinos have small mass,in beta decay, won't it affect the balance of the equation?
Also does anti neutrino differ from neutrino only in spin?
No, no an antineutrino can have the same spin as a neutrino. Spin values can be positive or negative, i.e. +1/2 and -1/2 in your case. A neutrino and antineutrino can have both, spin +1/2 and -1/2.
If so what differs a neutrino from anti neutrino?
For one, the lepton charge (or lepton number).
How do you say that ? 1/2 is not some probabilistic mean over a range of values - it is exactly what you will measure for the spin of say, a single electron.
Oh! I thought that a particle may spin in clockwise or anti-clockwise direction both of which having a 50-50 probability and hence the value (1/2).Is it not so?
Will you give me proper article on any webpage about lepton charge?
I don't have an article, but electron number, muon number and tauon number are always observed to be conserved. Electrons and electron neutrinos have an electron number of 1, positrons and electron antineutrinos -1, likewise for muons, tauons and their respective neutrinos and antiparticles. I think this is a consequence of observed particle decays, rather than fundamental principal (that is, they are conserved because that's all we've seen).
On spin, the funny thing is that the choice of axis is entirely aribitrary. No matter how you measure the spin of an electron, say, you will measure the same value had you measured some other axis of spin. This is why it is not helpful to picture it as something actually spinning. When people say a particle is 'spin half', they mean the quantum number s for that particle is 1/2, from which the possible actual spin values S are deriveable in the same way as actual quantized angular momentum.
No. The spin up and down come from the eigenvalues of the spin up and spin down spinors which are hbar/2 and -hbar/2.
To tie everything together, a "spin 1/2" particle has spin quantum number [itex]s = 1/2[/itex]. The magnitude of the spin angular momentum is [itex]S = \sqrt{s(s+1)} \hbar = \sqrt{3/4} \hbar[/itex]. These are both fixed, constant values.
The z-component of the spin angular momentum is quantized according to [itex]S_z = m_s \hbar[/itex]. When [itex]s = 1/2[/itex], [itex]m_s[/itex] can be either +1/2 or -1/2. Therefore [itex]S_z[/itex] can be either [itex]+\hbar / 2[/itex] or [itex]-\hbar / 2[/itex]. These are the "spin up" and "spin down" states, and for an isolated particle should each occur with 50% probability.
Dirac spinors
Recently I have learned a little bit about Dirac spinors and have written a paper with my view of them:
http://arXiv.org/abs/math/0601262"
Maybe it will help you. Anyway, I would like to continue learning the elementary particles physics, so it would be best to discuss them here.
Metric connections for Dirac spinors
The next paper is on metric connections for Dirac spinors in a gravitational field:
http://arxiv.org/abs/math.DG/0602359"
