Projectile motion airplane speed problem
The discussion focuses on solving a projectile motion problem involving an airplane releasing a package. The airplane's speed is 97.5 m/s at a 50.0-degree angle, and the package is released from an altitude of 732 m. The initial horizontal and vertical velocity components are calculated as 62.7 m/s and 74.7 m/s, respectively. The time to impact is determined using the vertical motion equation, leading to the need for calculating the Y velocity at impact to find the angle of the velocity vector just before the package hits the ground.
  • Understanding of projectile motion principles
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with kinematic equations for motion
  • Basic concepts of vector resolution
  • Calculate the Y velocity at impact using kinematic equations
  • Determine the angle of the velocity vector before impact using arctangent
  • Explore the effects of air resistance on projectile motion
  • Review advanced projectile motion problems involving varying angles and speeds
Students and educators in physics, aerospace engineers, and anyone interested in understanding projectile motion and its applications in real-world scenarios.
dethlok777
An airplane with a speed of 97.5 m/s is climbing upward at an angel of 50.0 degrees with respect to the horizontal. When the plane's altitude is 732m, the pilot releases a package. (a) Calculate the distance along the ground, measured from a point directly beneath the point of release, to where the package hits the earth. (b) Relative to the ground, determine the angle of the velocity vector of the package just before impact.
I started this problem by figuring out the velocity components for both the horizontal motion and the vertical motion of the package.
initial velocity of x=the inital velocity*cos(50.0 degrees)=62.7 m/s
initial velocity of y= the inital velocity *sin (50.0 degrees)=74.7 m/s
Then I thought I should find the time it takes for the package to hit the ground. using the equation y=initial velocity component y*t + 1/2(acceleration component of y*t*t)-->-732m=(74.7m/s)t + 1/2(-9.80m/(s*s))t*t = 22s
My question: Is this the direction I should be following to solve this problem or am I totally hosed up on this? Don't want the answer to the overall question but a hint to help me figure this out.
ps sorry about the t*t notation I could not figure out how to do superscripts or subscripts here.
Yes, you've got a good start on this problem, and resolving the velocities into X and Y is the right way to go. Now you have to determine the Y velocity at the time it hits the ground. With that, you have both the X and Y velocity just before impact, assuming the X velocity hasn't changed and neither velocity is a function of wind resistance. From that you can find the angle it is going upon impact, just as you resolved the X and Y from the initial angle.
  • · Replies 18 ·
  • · Replies 21 ·
