Doppler Effect: Does Wind Affect Pitch of Factory Whistle?
  • Context: Undergrad
  • Thread starter Thread starter barcat
The discussion centers on the impact of wind on the pitch of a factory whistle, concluding that wind does not affect pitch, although it may cause a delay in sound perception for those positioned upwind. The Doppler effect is defined as the change in frequency perceived by observers due to relative motion between the source and the observer, but if both are stationary, the pitch remains constant regardless of wind conditions. The analysis emphasizes that the medium's motion does not alter the pitch itself, only the timing of sound arrival.
  • Understanding of the Doppler effect
  • Basic knowledge of sound waves and frequency (Hz)
  • Familiarity with concepts of sound propagation in different media
  • Awareness of relative motion in physics
  • Research the principles of the Doppler effect in various mediums
  • Explore sound wave propagation and its dependence on environmental factors
  • Investigate the effects of wind speed on sound transmission
  • Learn about the physics of sound frequency and pitch perception
Students in physics, acoustics researchers, and anyone interested in the principles of sound and wave behavior in different environmental conditions.
barcat
I thought I would present this before I posted it on the mandatory
participation class ‘Discussion Board’. Any suggestion would be
appreciated. I'm sure you all have heard it before.
The question is- “Does wind affect the Pitch of the factory
whistle you hear on a windy day?"
The assignment illustration
shows a person down wind cupping his ear toward the sound of the
whistle .
My answer- No it does not (although there might be a delay in
hearing the sound by the one who is up wind of the whistle).
My reasoning- Pitch is a measure of the number of vibrations
(waves) that is experienced in a particular period of time (seconds),
through a particular medium (air) at a particular point. This
normally is represented in Hz (vibrations or wave lengths ‘lambda’
per second). The Doppler effect (which is really what the question
is a test of) is where differently orbital positioned receivers,
experience different pitches (Hz), after the sender has transmitted a
wave with a constant wave length and speed (Hz), while either the
receivers or the sender or both are in motion. If both the sender,
and the receiver are stationary, all receivers will experience the
same Pitch of vibrations that the sender is producing. This would be
true whether the medium (air) is in motion or not.
Further Critical Thinking- If (by chance) the receiver was upwind
and the air was blowing at or faster than the speed of sound, would
a receiver upwind of a sender ever hear the sound?
How far off base, with any of this, am I?
Yeah, I think you're right. If I remember correctly, as long as the source and observer have no relative velocity, there is no frequency shift (and, of course, both stationary constitutes no relative velocity). I think is is basically what you said, but I wanted to make sure you understood that they could both be in motion as well. In fact, as far as waves go, with respect to the medium, the source and observer are both in motion.
The moving medium was the kicker that caused me to question my reasoning. I’ve thought about it quit a bit, and finally decided that the medium effects only the time in which whatever ‘Hz’ of the wave is, is initially received by the receivers. I cannot see where the constant airflow would affect the ‘Pitch’.
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 24 ·
10K
  • · Replies 21 ·
