Designing a Balsa Wood Beam: Max Strength, Min Weight
The discussion focuses on designing a balsa wood beam with an optimal strength-to-weight ratio for a school project. Key parameters include a beam length of 500mm, with 25mm supports on either side, and a maximum width and depth of 100mm. The beam is considered to have failed once deflection reaches 50mm. Participants suggest using a nested architecture approach, incorporating cross-beams to enhance structural integrity and maximize load-bearing capacity.
  • Understanding of beam mechanics and structural engineering principles
  • Familiarity with stress and strain calculations for materials, specifically balsa wood
  • Knowledge of beam deflection theory and failure criteria
  • Basic skills in drafting and designing structural models
  • Research beam design formulas, focusing on bending stress and deflection calculations
  • Explore the properties of balsa wood, including density variations and their impact on strength
  • Learn about nested beam architecture and its advantages in structural reinforcement
  • Investigate software tools for structural analysis and design simulations
Students in engineering or architecture programs, hobbyists interested in model building, and anyone involved in structural design and optimization of lightweight materials.
Struggling
Hi for school i need to design a balsa wood beam. Winner is judged be strength to weight ratio.
i have searched around and found all the stress and strain values for balsa wood at different densitys etc...
now my dilemma is that i have to use formulas to design this beam before it is built. Iam having trouble getting started.
would anyone be able to point me in the right direction? iam a little confused as to were to begin, so much needs to be taken into consideration such as widths,lengths,density, forces etc etc
and how do i find the beam design that will hold the most amount of force?
beam needs to be 500mm long with 25mm supports on either side. total length 550mm
width and depth no more than 100 mm and the beam is said to have failed once deflection reaches 50mm.
please help thanks
please help thanks
Make a beam with a nested architecture: Construct cross-beams to reinforce the length, construct smaller cross-beams which reinforce the smaller cross-beams, make even smaller cross-beams which reinforce the smaller cross-beams. Keep nesting it until you get tired or run into a constraint.
20K
10K
