Length contraction equation. what am i doing wrong?
The discussion revolves around the length contraction equation in the context of special relativity, specifically focusing on determining the velocity (v) when given contracted length (L) and proper length (L*).
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to manipulate the length contraction formula but encounters results suggesting velocities exceeding the speed of light, prompting questions about their calculations and assumptions.
Participants are actively engaging with the original poster's calculations, offering corrections and pointing out errors in the algebraic manipulation of the equations. There is an acknowledgment of mistakes, and some participants provide alternative calculations to clarify the issue.
There is a focus on ensuring that the derived velocity does not exceed the speed of light, which is a fundamental constraint in relativity. The original poster expresses urgency for assistance.
Sneil
Length contraction equation determining v. what am i doing wrong?
OK,
L=L*(1-v2/c2)1/2 (to the power of 1/2)
L=.75m L*=1.0m
now i need to find v and for the life of me i always end up with a value greater then c which is obviously impossible.
ill simplify to v=
L/L*=(1-v2/c2)1/2
(L/L*)squared = 1-v2/c2
1+(L/L*)squared = v2/c2
(1+(L/L*)squared )to the 1/2=v/c
c((1+(L/L*)squared )to the 1/2)=v
and thus i break the barrier of the speed of light and go back in time i guess...
any help?? asap please :redface:
Sneil said:
OK,
L=.75m L*=1.0m
ill simplify to v=
L/L*=(1-v2/c2)1/2
Your mistake is on line 3. It should go:
[tex](\frac{L}{L*})^2=1-\frac{v^2}{c^2}[/tex]
[tex](\frac{L}{L*})^2-1=-\frac{v^2}{c^2}[/tex]
[tex]\frac{v^2}{c^2}=1-(\frac{L}{L*})^2[/tex]
Sneil said:
OK,
L=.75m L*=1.0m
ill simplify to v=
L/L*=(1-v2/c2)1/2
Let's see. L/L* is .75
(1 - v^2/c^2)^1/2 -.75
1 - v^2/c^2 = .5625
-v^2/c^2 = .5625 -1 = -.4375
v^2/c^2 = .4375
v/c = sqrt(.4375) = .661437828
So v is about 661/7 % of c.
Your error was in going from your second equation to your third. You got the signs wrong in simplifying. Check it out.
ah, great. bad mistake on my part. Thank you very much for the quick replies! :smile: :smile:
  • · Replies 36 ·
  • · Replies 67 ·
