The discussion revolves around the behavior of a sealed lead acid (SLA) battery pack during charging and discharging. Participants explore the implications of charging voltages exceeding recommended levels and the effects of drawing high current from the battery pack.
- Technical explanation
- Debate/contested
- One participant notes that during charging, two cells in the battery pack exceed the healthy voltage limit, while the other two remain within acceptable levels.
- Another participant suggests that charging the SLA batteries at 16A could potentially damage them and recommends limiting charging time and monitoring voltage.
- A clarification is made regarding the distinction between charge current and drain current, indicating that the maximum charge current should be around 2A.
- One participant expresses that drawing 16A from the pack may not damage the batteries, despite the short duration of use (approximately 1/2 hour).
Participants express differing views on the potential damage to the battery pack from both high charging currents and high discharge currents. There is no consensus on whether drawing 16A will harm the pack.
Participants discuss the implications of charging voltages and current limits without resolving the underlying assumptions about battery health and performance under specific conditions.
