Solve 10 US gal of Jell-O Freezing in Locker Freezer at -10 °F
  • Thread starter Thread starter Jell-O Man
The discussion focuses on calculating the cooling time for 10 US gallons of a Jell-O solution in a locker freezer at -10 °F. The solution consists of 5 gallons of boiling water mixed with 5 gallons of a 99% water solution. To determine the cooling time to 35 °F, participants suggest using Newton's law of cooling, represented by the formula q = m C_p ΔT, where the specific heat of the mixture must be calculated. Additionally, the freezer's cooling capacity in BTU/min is essential for accurate time estimation.
  • Understanding of Newton's Law of Cooling
  • Knowledge of specific heat capacity calculations
  • Familiarity with BTU (British Thermal Unit) as a measure of heat
  • Basic chemistry concepts related to mixtures
  • Research specific heat calculations for mixtures, particularly water-based solutions
  • Learn how to measure and calculate BTU/min for refrigeration systems
  • Explore Newton's Law of Cooling in detail, including practical applications
  • Investigate the thermal properties of Jell-O and similar gelatinous substances
Students in science projects, educators teaching thermodynamics, and anyone interested in practical applications of heat transfer principles.
Jell-O Man
As I am actually performing this, it occurred to me I'm a bit rusty and cannot define the formula to calculate the following process. Anyone who can solve this and show a proof, your help would be appreciated. NO, I'm not a student looking for someone to do my work, I've been out of school for 7 years... which is why I'm rusty.
10 US gal of a solution is made using 5 gal of boiling water, added to 5 gal of a solution (which is 99% water).
These 10 gal are then placed in an empty locker freezer, which is approx 10 cubic ft, and has an ambient temp of -10 degrees(F).
My question is: how long should it take to cool the solution to 35 degrees(F)?
I have not been able to figure out cold output of the freezer, so answer would have to use a variable to define the strength of the freezer's output in the formula for "t".
Thanks in advance.
Without going into a huge heat transfer analysis, I'd estimate it using Newton's law of cooling:
[tex]q = m C_p \Delta T[/tex]
The only thing you'll have to do is to use a bit of chemistry to calculate the specific heat of the mixture. Once you know that, you need the capacity of the freezer in some units along the lines of btu/min to calculate the time necessary.
Hello,
I am a student doing a science project where I need to know the specific heat of Jell-O. I googled "specific heat of Jell-O" and this thread came up. Sorry to be a bit random, but do you know the specific heat of Jell-O? It would help me immensely, as I have not had enough schooling yet to know how to calculate this.
Thank you,
A middle school student
  • · Replies 20 ·
