Solve Exponential Function: 2 Questions | Help Needed
The discussion revolves around solving two exponential equations. The first equation involves manipulating bases of fractions raised to variable powers, while the second equation requires solving a quadratic form derived from an exponential expression.
  • Mixed
  • Participants explore various algebraic manipulations to simplify the first equation, questioning their steps and results. For the second equation, there is a suggestion to substitute a variable to transform it into a quadratic equation, with participants discussing the implications of this approach.
Some participants have provided guidance on recognizing relationships between bases and simplifying expressions. Others are attempting to clarify their reasoning and steps, leading to a deeper exploration of the problems without reaching a consensus on the final solutions.
Participants express challenges with the clarity of their algebraic steps and the potential for errors in manipulation. There is also mention of specific values being derived from the quadratic equation, but no definitive conclusions are drawn regarding the correctness of those values.
love_joyously
i'm having problems with two questions. Please help me! Thanks! I've tried everything but i can't solve them... :confused: :frown:
1) Solve: (3/4)^3x-2 * (4/3)^1-x = 9/16
2) Solve for x : 3(3^x) + 9(3^-x)=28
Could you please show us what you've tried?
Well for no. 1 this is what I've tried but i keep getting the wrong answer:
*2nd step* 3^3x-2/ (2^2)^3x-2 * (2^2)^1-x/3^1-x = 9/16
3^3x-2/2^6x-4 * 2^2-2x^3^1-x = 9/16
2^-8x+6/3^-4x+3 = 3^2/2^4
Therefore, -8x+6/-4x+3 = 1/2
-16x +12 = -4x +3
-12x = -9
x = 3/4
*the answer was 5/4*
and for no.2 i have no idea what my next step is...
There's a much easier way.
First, recognize that [itex]\frac{4}{3}=(\frac{3}{4})^{-1}[/itex] and that [itex]\frac{9}{16}=(\frac{3}{4})^2[/itex].
Once you do that, all the bases will be the same. Then you can apply the rule [itex]a^xa^y=a^{x+y}[/itex] to simplify the left side, and then solve the equation.
You'll want to do something similar to reduce the left side of #2 to a single term.
I'm trying to follow your work, but it's very difficult to read.
Here is your second step in Latex form. Maybe you could rewrite the next steps.
[tex]\frac{3^{3x-2}}{(2^2)^{3x-2}}*\frac{(2^2)^{1-x}}{3^{1-x}}[/tex]
yeah, sure, ill try. Then ill let you know
i tried it but i keep eliminating my variable
How? When you add the exponents, the variable does not cancel out.
ok.. well this is what i did:
3^3x-2/2^6x-4 * 3^x-1/2^2x-2 = 3^2/2^4
3^4x-3/2^8x-6=3^2/2^4
Therefore, 4x-3/8x-3 = 1/2
*cross-multiply* 8x-6 = 8x-6
0=0
This step is wrong.
You'll have better luck if you don't use different exponents for the numerator and denominator.
[tex]\left(\frac{3}{4}\right)^{3x-2}\left(\frac{3}{4}\right)^{x-1}=\left(\frac{3}{4}\right)^2[/tex]
Now you can simply add the exponents on the left side, and solve for x.
ook.. i get : (3/4)^4x-3 = (3/4)^2
wat now?
See how the bases are equal? That means that the exponents must be equal in order for the equation to hold. Set them equal, then solve for x.
wat now?
I know know this problem,
4x-3=2
then x=5/4
oh..ok! now i get it.. thanks!
so for no. 2, what do u suggest me do?
let t=3^x then Solve for t : 3t^2 -28t + 9=0
Yeah..
Yeah..
That's what I would do, too. Solve that quadratic equation, then solve for x.
I was trying to follow what you did to arrive at the quadratic expression.
It seems you multiplied the original equation by [itex]3^x[/itex]
[itex]3^x [ {3(3^x)+9(3^{-x})=28}][/itex]
[itex]3(3^x)^2 +9 = 28(3^x)[/itex]
[itex]3(3^x)^2 -28(3^x) +9 = 0[/itex]
And If [itex]t = 3^x[/itex] then [itex]3t^2-28t+9=0[/itex]
With a bit of http://www.deephousepage.com/smilies/OLA.gif I get, x = -1, 2
  • · Replies 88 ·
  • · Replies 29 ·
