MgB2 Brittle? Superconductor q's & Experiments
  • Context: Graduate
  • Thread starter Thread starter sniffer
    Superconductor
MgB2 is confirmed to be brittle and cannot be drawn into wire; however, it can be formed into wires by compacting fine MgB2 powder inside a thin tube. The critical temperature (Tc) of MgB2 is approximately 38K, necessitating the use of liquid helium for cooling, as opposed to liquid nitrogen, which is suitable for higher Tc superconductors like YBCO and BSCCO. While liquid nitrogen is commonly used in many superconductor experiments, its application for MgB2 is not appropriate due to its lower Tc.
  • Understanding of superconductivity and critical temperature (Tc)
  • Familiarity with MgB2 properties and applications
  • Knowledge of cooling methods for superconductors, specifically liquid helium and liquid nitrogen
  • Basic concepts of wire fabrication techniques for brittle materials
  • Research the fabrication techniques for MgB2 wires using powder compaction
  • Explore the properties and applications of high-temperature superconductors (HTSCs) like YBCO and BSCCO
  • Learn about the thermal noise implications in superconducting applications, particularly in SQUIDs
  • Investigate the cooling methods for superconductors, focusing on the differences between liquid nitrogen and liquid helium
Researchers, physicists, and engineers working in superconductivity, particularly those involved in the development and application of MgB2 and other superconducting materials.
sniffer
1. is MgB2 brittle? can we draw it like wire and wind it up make a coil/electromagnet with it?
2. liquid nitrogen boils at 77K and freezes at 63K. most superconductor experiments use liquid nitrogen, so does it mean most applications use this temperature range (eg. for squid)? what about those people using liquid nitrogen for mgb2 experiment? use liquid helium?
thanks.
This is Zz's area, but so far the questions look pretty straightforward.
1. Yes, I believe MgB2 is fairly brittle. It can not be drawn (forged) into a wire. However, this does not prevent the making of MgB2 wires - the trick is to use a fine powder of MgB2 which is compacted inside a thin tube.
2. Since many of the Cuprate based (eg : YBCO, BSCCO, etc.) HTSCs have Tc above 77K, they are used/studied under liq. nitrogen. MgB2 has its higher Tc at about 45K, and IS hence cooled by liq. Helium, as you guessed.
thanks.
Er... MgB2 has a Tc of 38K. Why would anyone use LN2 for this?
Even for high Tc cuprates, which would have Tc above LN2 temperature, it depends on what you want to use it for. The higher the temperature, the larger the "thermal noise". So for squid application especially, where you may have to detect up to 1 unit flux, you do this at as low of a temperature as you can. But if all one wants is any kind of superconductivity, then using LN2 would be sufficient.
Zz.
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 28 ·
  • · Replies 21 ·
9K
