Voltmeter Measurement: Peak vs RMS?
The discussion revolves around the measurement capabilities of voltmeters, specifically whether they report peak voltage or RMS (root mean square) voltage. The original poster seeks clarification on the standard reporting of voltmeters in the context of a physics lab assignment.
  • Participants explore the typical specifications of voltmeters, questioning whether they report peak or RMS values. There is a discussion about the reliability of readings from different types of voltmeters, including those labeled as "true RMS."
Participants are sharing insights about voltmeter types and their measurement characteristics. Some guidance has been provided regarding the distinction between true RMS and other types of voltmeters, but there is no explicit consensus on the original poster's specific situation.
The original poster is working on a lab assignment and is uncertain about the type of voltmeter used, which may affect their calculations for RMS current. There is mention of varying voltmeter specifications and potential misinformation regarding their capabilities.
discoverer02
I took some measurements for a Physics lab and don't recall whether the Voltmeter I used reports the peak voltage or rms voltage. I need rms voltage to calculate the rms current. Can anyone tell me what the norm is for voltmeters: peak or rms?
To divide by the [squ]2 or not to divide by the [squ]2, that is the question.
Thanks.
My guess, RMS.
Hey, that rhymed.
If it was giving you a steady reading for AC voltage, it was probably RMS.
Actually, the vasssssst majority of AC voltmeters are peak-to-peak. Some of them which say "RMS" actually only give the correct RMS voltage at one frequency, usually 60 Hz. Only a meter which says "true RMS" will actually give you the RMS amplitude at all frequencies.
Just because the meter is not true RMS does not mean it will not give a steady reading -- it will. It'll just be an incorrect steady reading.
- Warren
Fair enough. The Fluke handhelds I always use always give me true RMS. I shouldn't have assumed that applied to others considering what happens when you assume... Sorry if I was the source of misinformation.
I vaguely remember the instructor saying something about the meter measuring the peak voltage, but needed to confirm before I finish my lab assignment.
Thanks very much for the help.
