How to calculate speed and time in threaded motion
The discussion revolves around calculating speed, time, velocity, distance, and acceleration in threaded motion, particularly in the context of screw and nut arrangements. Participants explore the relationship between rotary motion and linear motion, as well as the kinetic energy involved in such systems.
  • One participant inquires about the calculations needed for velocity, distance, speed, and acceleration in threaded motion, specifically in a screw and nut arrangement when torque is applied.
  • Another participant suggests that the inquiry may relate to lead screws and provides a formula for calculating linear movement based on turns per inch (TPI) and rotation speed, noting that efficiency of the threads is a factor.
  • It is mentioned that for calculating the velocity or acceleration of the carrier, efficiency or friction of the screw may not be necessary, but would be important when calculating required torque or forces.
  • A reference link is provided for further information on motion control, although its relevance to the specific calculations is not clarified.
Participants have not reached a consensus, as there are varying interpretations of the initial question and differing approaches to the calculations involved.
Some assumptions about the specific type of screw mechanism and its efficiency are not fully articulated, and the discussion does not resolve the mathematical steps needed for the calculations.
indianmc
sir,
if the motion has been through the fastener arrangement or the rotary motion is used to get the linear motion. then how do we have to calculate the velocity and distance nd speeed as well as accelaraion?
e.g. in a screw and nut arrangement. if i apply the moment of torque/force. the screw is to be traversed from one pich to other then how tho calculate the kinetic energy involved in it. and also the velocity with which it moves
etc.
I'm not exactly sure what you are asking - can you post a diagram?
I assume you're talking about something like a lead screw?
For a single-start screw, the TPI (turns per inch or threads per inch - the same for a single-start) divided by the rotation give linear movements.
15 TPI spun at 900 RPM would work out to 60 inches/min or 1 inch/sec
You can find the others from that, but you also should factor in the efficiency of the threads. An ACME-style squared teeth thread, one designed for linear motion, is going to have much greater efficiency at moving a load than a thread design like found on a conventional bolt/nut in a hardware store designed more to 'lock' when under load clamping/fastening. This will influence your power/force figures since the input/output will not be on a linear relationship for conventional threads, and the coefficient of friction will also influence those numbers.
As a note: If you're talking about the velocity/acceleration of the carrier then you really don't need to think about efficiency or friction of the screw. If you are calculating required torque or forces to produce that, then yes, you would need to look at those things.
Here's a quick and dirty reference from some motion control folks:
http://www.techno-isel.com/Tic/H834/PDF/H834P011.pdf
  • · Replies 23 ·
