Parallel-Plate Vacuum Capacitor
  • Thread starter Thread starter LostinPhysics
    Capacitor Vacuum
The discussion focuses on the energy stored in a parallel-plate vacuum capacitor when the separation between the plates is altered. Initially, the capacitor has energy U stored with plate separation x1. When the separation is decreased to x2, the energy can be recalculated using the formula U = Q² / (2C), where Q remains constant since the capacitor is disconnected from the potential source. The capacitance for both configurations must be determined to find the new energy stored after the change in separation.
  • Understanding of capacitor fundamentals, specifically parallel-plate capacitors.
  • Familiarity with the formulas for capacitance and energy storage in capacitors.
  • Knowledge of electric charge conservation principles.
  • Basic algebra skills for manipulating equations.
  • Study the derivation of the capacitance formula for parallel-plate capacitors.
  • Learn how to calculate energy stored in capacitors using different configurations.
  • Explore the implications of charge conservation in disconnected capacitors.
  • Investigate the effects of varying plate separation on capacitance and energy storage.
Electrical engineers, physics students, and anyone interested in understanding capacitor behavior in circuit design and energy storage applications.
LostinPhysics
If a parallel-plate vacuum capacitor, with its plates separated by a distance of x1 has an amount of energy equal to U stored in it. The separation is then decreased to x2 .
What is the energy now stored if the capacitor was disconnected from the potential source before the separation of the plates was changed? I know that I am suppose to use the formula C= Q/V but how do I put U in terms of x1 and x2?
As the battery is disconnected, the charge on the capacitor plates becomes constant. Now by changing capacitance the potential difference will change and hence it is batter to use the formula Q^2 /2C of the energy.
Capacitance in the two situations are to be calculated and Q is calculated by first situation only.
  • · Replies 20 ·
  • · Replies 20 ·
