Proving "No Convergent Subsequence -> |s| Diverges to Infinity"
The discussion revolves around the proof that if the sequence {s} has no convergent subsequence, then the sequence of absolute values {|s|} diverges to infinity. Participants are exploring the implications of convergence and subsequences within the context of real analysis.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants are attempting to use contradiction to establish a link between the convergence of {|s|} and the existence of a convergent subsequence in {s}. There are questions about the relationship between subsequences and the definitions of convergence.
The conversation is ongoing, with some participants questioning the original problem's wording and the implications of "diverging to infinity." Clarifications about the definitions and properties of convergent sequences are being sought, indicating a productive exploration of the topic.
There is some uncertainty regarding the terminology used in the problem statement, particularly what "diverges to infinity" entails. Participants are also reflecting on theorems related to compactness and subsequences in the context of real analysis.
happyg1
Hi,
Here is the question:
Prove that if the sequence {s} has no convergent subsequence then {|s|} diverges to infinity.
To me, this seems so easy, but I'm having a really hard time putting it down in a rigorous manner.
My thoughts are:
every convergent sequence has a convergent subsequence (theorem in the book), so if there is no convergent subsequence, then the sequence itsself cannot converge either.
So the absolute value won't converge.
I tried to do it with contradiction as follows:
Suppose that |s| converges. Then it has a convergent subsequence. Since |s| is also a subsequence of {s}, the convergent subsequence of |s| lies inside {s}. So {s} has a convergent subsequence. Contradiction.
Any clarification will be greatly appreciated.
CC
There is a problem with your logic in that {|s|} is not necessarily a subsequence of {s}. This is true even for convergent series like:
[tex]s_n = \frac{(-1)^n}{n}[/tex]
Carl
Ok,
I see that. Can I say that the elements a convergent subsequence of |s| also are members of {s}? The convergent subsequence of |s| will be positive numbers converging to L, so {s} will either have the same exact subsequence of positive terms, or it'll be negative terms, but then will converge to -L
happyg1,
Was the original problem "Prove that if the sequence {s} has no convergent subsequence then {|s|} diverges to infinity.", or was it instead "Prove that if the sequence {s} has no convergent subsequence then [itex]\sum |s|[/itex] diverges to infinity."
The reason I ask this is because I'm not really sure what "diverges to infinity" means.
If the meaning is to say that given a number L, no matter how far down the series you look, you can find an element larger in absolute value than L, then I can see your terminology working.
The whole thing smells of recourse to an argument based on the fact that any sequence that stays inside a closed subset of the real line has a convergent subsequence.
Carl
that is the question as printed in my book.
Then I think you will need to make an argument based on a fact that I vaguely recall to the effect that any sequence to a compact space has a subsequence that converges to an element of the compact space.
Hey, it's been about 30 years since I studied this, and this is the limit of what I can help.
Carl
