Where to Start with Electrochemistry Research for PEM Fuel Cells?
The discussion centers around starting research in electrochemistry, specifically related to Proton Exchange Membrane (PEM) fuel cells. Participants share resources, clarify concepts, and discuss experimental experiences in the context of electrochemical reactions.
  • Experimental/applied
  • Participants share various online resources and websites for learning about electrochemistry and PEM fuel cells.
  • One participant describes an electrochemical reaction as involving the abandonment of electrons by reactants, specifically in the context of hydrogen reacting with a catalyst in fuel cells.
  • Another participant challenges the necessity of a catalyst in electrochemical reactions, suggesting that reactions can occur without one.
  • There is a distinction made between galvanic and electrolytic reactions, with the former producing electricity and the latter requiring an applied electric potential.
  • Corrosion is mentioned as another example of an electrochemical reaction that does not require a catalyst.
  • A participant shares an experimental attempt involving sulfuric acid and a battery, expressing confusion over the lack of observable reaction and the heating of the wire.
  • Concerns are raised about safety and the need for a solid understanding of electrochemistry before conducting experiments.
  • There is a request for recommendations on textbooks available online for further study.
Participants generally agree on the importance of understanding electrochemical concepts, but there are differing views on the necessity of catalysts in electrochemical reactions and the interpretation of experimental results.
Some participants express uncertainty about the outcomes of their experiments and the implications of their observations, indicating a need for further clarification of concepts and safety precautions.
This discussion may be useful for students and researchers interested in electrochemistry, particularly those focusing on fuel cells and experimental approaches in the field.
P-man
I would like to do some research on electrochemistry, seeing as I'm doing a project on PEM Fuel Cells, but where should I start? Do you know any good books? Websites? Contacts?
Thanks, Pierre.o:) :smile:
Chemistry news on Phys.org
Thanks a lot.
Some other useful places besides the great sites Gokul mentioned.
http://www.fctec.com/fctec_types_pem.asp
http://www.fctec.com/fctec_basics.asp
http://www.bellona.no/en/energy/hydrogen/report_6-2002/22984.html
http://www.fuelcelltoday.com/FuelCellToday/EducationCentre/EducationCentreExternal/EduCentreDisplay/0,1741,FCInfoTypes,00.html
http://www.fuelcell.com/index.asp (more of commercial site)
http://en.wikipedia.org/wiki/Category:Electrochemistry (probably not as good as hyperphysics)
this might be useful - http://en.wikipedia.org/wiki/Table_of_standard_electrode_potentials
http://www.azonano.com/details.asp?ArticleID=1166
http://www.eere.energy.gov/hydrogenandfuelcells/
Thanks a lot for the great sites. From what I can gather now, an electrochemical reaction is a chemical reaction that takes place when one of the reactants is forced to abandon one or more electrons in the reaction. In a fuel cell, the hydrogen reacts with the catalyst (platinum, or nickel if the hydrogen is pure (from electrolysis)) and the hydrogen is forced to abandon its electrons in order to get to the oxygen on the other side of the membrane. Does there always have to be a catalyst in an electrochemical reaction? For it to be an electrochemical reaction, the reaction must produce electricity, in one way or another, if I am not mistaken?
This is true of almost any reaction, not just electrochemical reactions.
No, not at all.
Either that, or it must be caused by an applied electric potential. The first is a galvanic reaction, the second is an electrolytic reaction.
As Gokul pointed out, this is a special type of electrochemical reaction. There are others.
Corrosion is essentially an electrochemical reaction, and a catalyst is not needed.
Look at the Galvanic Cells - http://en.wikipedia.org/wiki/Galvanic_cell, and at hyperphysics though the links Gokul provided - http://hyperphysics.phy-astr.gsu.edu/hbase/chemical/electrochem.html#c1 and http://hyperphysics.phy-astr.gsu.edu/hbase/chemical/redoxcon.html#c1.
Reduction and Oxidation are chemical and electrochemical concepts.
Thanks guys. I appreciate your help. Now I understand what happens in the fuel cell better. But one more thing, today I was experimenting with electrochemistry, from what I knew, so I did this: I put some sulphuric acid in one test tube and some other base liquid I forget... and I put a battery and connected the two test tubes through my little circuit. I felt an electric shock near the battery but nothing seemed to happen in the test tubes, though the wire go really hot. Can you explaine this?
1. You need to learn a lot more. Make sure you can solve textbook (say Atkins, Phys Chem) problems on Electrochemistry before playing around with stuff. You can do dangerous things if you do not completely understand the concepts.
2. Without a good description/picture of your circuit, it's hard to say what happened. Looks to me like you just ended up shorting the terminals of the battery. This is not a good thing. If you have a voltmeter/multimeter, check the open circuit voltage across the battery terminals and make sure the battery is still good. If the voltage measured is less than the rated voltage, you probably fried your battery.
That doesn't sound to great.
Anyways, are there any textbooks I can find online?
  • · Replies 23 ·
  • · Replies 26 ·
