Internal Combustion Engine Fundamentals
Knocking in a spark-ignition (SI) engine is not caused by a single shock wave but rather by multiple small spheroidal shock waves that interact locally within the fuel mixture. This phenomenon leads to the formation of a pressure front, which can cause significant engine damage. A shock wave with a low pressure gradient of 1 bar is unlikely to exist and would not be sufficient to cause damage. The discussion references the book Internal Combustion Engine Fundamentals as a key resource for understanding these dynamics.
  • Understanding of spark-ignition (SI) engine operation
  • Familiarity with shock wave dynamics
  • Knowledge of pressure gradients and their effects on materials
  • Basic principles of combustion chemistry
  • Study the mechanics of shock waves in fluid dynamics
  • Research the effects of pressure gradients on engine components
  • Explore combustion chemistry related to knocking in SI engines
  • Learn about stress analysis in materials, particularly steel, under explosive conditions
Engineers, automotive technicians, and students studying mechanical engineering or automotive technology will benefit from this discussion, particularly those interested in internal combustion engine performance and failure analysis.
sid_galt
In an SI engine, according to the book Internal Combustion Engine Fundamentals, knocking is produced due to the interaction of the shock wave and the expansion wave which together produce very high amplitude standing waves.
My question is, in knocking is there only one shock wave or multiple shock waves?
Would a single shock wave with a low pressure gradient (say 1 bar) be sufficient to damage the engine?
I have never heard that knocking was caused by that. That's a poor explanation of knocking, which has its ultimate fundamentals in the Chemics involved.
You shouldn't view knocking as a single detonative shock wave traveling inside the cylinder. Knocking is caused locally, in each element of mixture, and spreads a great amount of small spheroidal shocks which interact one each other. All of them gather togheter to form a pressure front.
On the other hand, I doubt very much that a shock wave with such a low pressure gradient can exist. You should be able to work out how much damage can provoke. Just solve the pressure produced and calculate the stress exerted by the explosion in the piston rod, and compare it with the elastic limit of steel.
Speaking as one who has blown a hole the size of a golf ball in a piston... ouch!
  • · Replies 26 ·
  • · Replies 29 ·
9K
