Solving Derivative Problems - Hints for Parts d & e
  • Thread starter Thread starter seiferseph
    Derivative
The discussion revolves around derivative problems, specifically focusing on the behavior of a particle's velocity and acceleration over time. Participants are examining parts d and e of a problem related to motion, where they analyze the conditions under which the particle is moving left or right and when it is speeding up or slowing down.
  • The original poster attempts to determine the intervals for which the particle is moving left and right based on the sign of the velocity function. They also explore the conditions for speeding up and slowing down based on the relationship between velocity and acceleration.
Some participants express agreement with the original poster's findings regarding parts d and e. Others provide clarifications about the conditions for speeding up and slowing down, emphasizing the importance of the signs of velocity and acceleration. There is an ongoing exploration of these concepts without a definitive consensus on the interpretations.
Participants note potential confusion regarding the interpretation of the signs of velocity and acceleration, as well as the implications for the motion of the particle. There are references to specific time intervals and conditions that may require further clarification.
seiferseph
1) I'm having trouble with this problem, it looks like their isn't enough information. can someone give me some hints please
http://i2.photobucket.com/albums/y15/seiferseph/untitled.jpg
2)
http://i2.photobucket.com/albums/y15/seiferseph/untitled2.jpg
i solved parts a-c fine, but I'm having some trouble with d and e
i solved v(t) 6t^2 - 30t + 2 and a(t) = 12t - 30 (taking the derivative). for d and e it is looking for a range, right? here's what i got
d) it is moving left when v(t) < 0, so between the zeros, or 0.676 < t < 4.93
and it is moving right when v(t) > 0, or t < 0.676 and t>2.5
e) p is speeding up when both v(t) and a(t) are in the same direction, and slowing down when they are opposite directions (signs)
i got a(t) > 0 when t > 5/2, and a(t) < 0 when t < 5/2. so its speeding up when t > 4.93 and slowing when 0.676 < t < 2.5
thanks in advance!
For 1),
y = x²
y' = 2x
From this you can get the slope of the tangent at A(1,1) , hence also the slope of the normal. You know the coordinates of a point and the slope of the line passing through that point, A, hence you can find the eqn of that line.
Will that get you started ?
I agree with your answers for parts d) and e).
Fermat said:
For 1),
y = x²
y' = 2x
yes that helped, thanks! i guess i just saw it and got confused
so here's what i did, i sovled the slope of the normal line to be -1/2, which gave it the equation y = -1/2x + 3/2; i equated this to y=x^2 to solve for the intersection points, which i got to be (1, 1) and (-3/2, 9/4). i solved for the tangent line for x = -3/2 to get the slope to be -3, and i get the line equation to be y = -3x - 9/4. is this correct?
btw, thanks for confirming the other one too! i just worked my way through it, i haven't seen a problem like that before
I get the same as yourself for all the results you gave :smile:
thanks again, but i was thinking about part e of that second question, and when is it actually slowing down? would it be when they have the opposite sign? how does that work?
It is slowing down when velocity and acceleration have opposite signs.
Consider the eqn of motion,
vf = vi + at
where vf is the final velocity after time t, and vi is some inital velocity.
Let vf be +ve (positive) and let a be -ve (negative).
If a is -ve, then vi +at will be continually getting smaller as t increases, hence vf (= vi + at) will be decreasing. So the speed is getting (numerically) smaller.
Now, let vf be -ve and let a be +ve.
If a is +ve, then vi +at will be continually getting larger as t increases, hence vf (= vi + at) will be increasing.
But vf is -ve. And when -ve numbers increase they get numerically smaller. i.e the speed is getting smaller.
so for this problem would it be
speeding up when t>4.93 and when 0.676 < t < 2.5 ? and slowing down when they are opposite signs, at 2.5 < t < 4.93 and t < 0.676? i don't completely understand when it would be speeding or slowing in this problem...
  • · Replies 19 ·
