The Water Level Rises - Investigating the Melting Ice Cube
The discussion revolves around the question of what happens to the water level in a glass when a floating ice cube melts. Participants explore the implications of buoyancy, density, and the properties of water at different temperatures, addressing both theoretical and practical aspects of the scenario.
  • Some participants argue that the water level will drop when the ice melts due to the lower density of ice compared to water.
  • Others contend that the water level will remain the same because the mass of the melted ice will replace the volume of water originally displaced by the ice cube.
  • A participant questions whether a perfect ice cube is entirely crystalline and discusses the potential dynamic state of the ice surface.
  • Another viewpoint suggests that the water level may lower and then rise, referencing the varying density of water at different temperatures, particularly around 3 or 4 degrees Celsius.
  • Concerns are raised about the lack of information regarding the initial temperatures and masses of the water and ice, which could affect the outcome.
Participants express differing opinions on the outcome of the water level change, with no consensus reached. Multiple competing views remain regarding the effects of melting ice on water displacement and the influence of temperature on water density.
Limitations include the dependence on specific conditions such as the initial temperatures of the water and ice, which are not provided, and the assumptions about the properties of the ice cube.
chemical
stuck in explaining this problem
A glass of water contains a large ice cube
the glass can hold no morw water
the ice is floating in the water
what will happen to the water level when the ice melts?
Originally posted by Guybrush Threepwood
the level will drop.
the ice has a density a bit lower than the water (that's why ice is floating).
http://www.its.caltech.edu/~atomic/snowcrystals/ice/ice.htm
I disagree. The ice cube is made wholly of water in a cryistaline form and therefore its mass although lower than liquid water would still diplace the same amount of water as is contained within the cube. if the cube melts the water from it will replace exactly the water that was originally displaced by the cube. therefore the level will remain the same.
Rog has it right. A floating object displaces its mass, a sunken one displaces its volume. Remember Archimedes.
Njorl
Is a perfect ice cube is made of wholly crystaline water? Aside from bubbles or such trapped particles, (which I am discounting), does the surface of the cube remain as a solid, or is it in a dynamic process of changing it's state?
It doesn't matter. Even if the ice cube was an ice bubble, the amount of water it displaces is identical [to the volume (melted) of the water contained in the ice].
I know the answer to this question! I did this question for my hw.
The answer is the water level will lower and then rise. I'm not sure at what temp, but water has a different density at certain temp. I think near 3 or 4 C, the density is lower than at other temp.
H20 does some strange things around its melting point, there is not really enough information in the problem to allow for those small effects. You would need to know the starting temperature of the water, and the ice, and their masses etc. If the thermal expansion coefficient of liquid water were monotonic, you could do what you say, but water is at it's maximum density at 4 degrees C I believe. Heat it or cool it from that point and it expands.
Njorl
13K
9K
