Bohr's Atomic Model: Magnetic vs Gravitational Force
The discussion revolves around the inaccuracies of Bohr's Atomic Model, particularly focusing on the differences between magnetic and gravitational forces and their implications for orbital stability. Participants explore the reasons why electrons in atoms behave differently from planets in a solar system, addressing concepts of radiation and energy loss in classical physics.
  • Some participants note that Bohr's model inaccurately suggests that electrons would spiral into the nucleus due to the attractive force, similar to how a planet would be expected to spiral into a star.
  • Others argue that the electron's charge leads to energy radiation when accelerating, causing it to lose energy and spiral into the nucleus, a phenomenon not applicable to planets.
  • A participant introduces the idea that gravitational radiation exists, suggesting that planets also radiate energy, albeit at a much weaker level than electrons in the Bohr model.
  • Some participants discuss the differences in radiation mechanisms between electromagnetic and gravitational forces, highlighting that gravitational radiation is suppressed compared to electromagnetic radiation.
  • A later reply clarifies that Bohr's model postulates quantized orbits for electrons, which prevents them from radiating energy while in these stable states, contrasting with earlier models that did not account for this quantization.
  • There is a question raised about whether the electron changes direction during its orbit, with responses indicating that in classical terms, the electron's direction is indeed constantly changing.
Participants express differing views on the implications of radiation for electrons and planets, with no consensus reached on the overall accuracy of Bohr's model or the comparison between magnetic and gravitational forces.
Some limitations in the discussion include assumptions about the nature of radiation, the applicability of classical physics to atomic models, and the scope of gravitational effects in planetary systems versus atomic systems.
tiagobt
My physics teacher told me that one of the innacuracies of Bohr's Atomic Model is that the nucleus (positive) would attract the electron (negative) making it move as a spiral until it collapses with the nucleus. What I don't get is why the same thing doesn't happen with a planetary system. How different is magnetic force from gravitational force?
The reason has to do with the fact that the electron has a charge, and that--according to classical physics--accelerating charges radiate energy. Thus the orbiting electron would quickly lose its energy and spiral into the nucleus.
That doesn't happen to planets.
The "spiraling" mechanism involves the emission of electromagnetic waves (for charges), or gravitational waves (for masses) which are necessary to maintain the conservation of momentum.
In theory, the Earth does spiral into the sun via the emission of gravitational radiation - it is just that this is a very weak effect. (So weak that it cannot be directly observed).
Gravity is universally attractive, so there can be no dipole terms to generate gravitational radiation. The first terms which can generate gravitational radiation are quadropole terms. This means that gravitational radiation is surpressed even more than electromagnetic radiation.
See for instance the sci.physics.faq
http://math.ucr.edu/home/baez/physics/Relativity/GR/grav_speed.html
Since this point can be confusing, it's worth exploring a little further, in a slightly more technical manner. Consider two bodies--call them A and B--held in orbit by either electrical or gravitational attraction. As long as the force on A points directly towards B and vice versa, a stable orbit is possible. If the force on A points instead towards the retarded (propagation-time-delayed) position of B, on the other hand, the effect is to add a new component of force in the direction of A's motion, causing instability of the orbit. This instability, in turn, leads to a change in the mechanical angular momentum of the A-B system. But total angular momentum is conserved, so this change can only occur if some of the angular momentum of the A-B system is carried away by electromagnetic or gravitational radiation.
Now, in electrodynamics, a charge moving at a constant velocity does not radiate. (Technically, the lowest order radiation is dipole radiation, which depends on the acceleration.) So, to the extent that A's motion can be approximated as motion at a constant velocity, A cannot lose angular momentum. For the theory to be consistent, there must therefore be compensating terms that partially cancel the instability of the orbit caused by retardation. This is exactly what happens; a calculation shows that the force on A points not towards B's retarded position, but towards B's "linearly extrapolated" retarded position. Similarly, in general relativity, a mass moving at a constant acceleration does not radiate (the lowest order radiation is quadrupole), so for consistency, an even more complete cancellation of the effect of retardation must occur. This is exactly what one finds when one solves the equations of motion in general relativity.
what about gravitational radiation? isn't there some energy radiated as gravity waves because of the accelerated masses of the planets? (admittedly, the acceleration is far less than that in the Bohr model.)
Absolutely, as pervect explained. (I ignored such small effects in my response; pervect's post is more complete and accurate.)
Actually, this is a problem with a predecessor to Bohr's model, not with Bohr's model itself. Before Bohr entered the picture, physicists considered what one might call the "naïve planetary model" of the atom, in which the electrons are classical particles orbiting the nucleus under the influence of the electric force. This model was quickly seen to have the "radiation problem" discussed in this thread.
Bohr's model specifically postulated that atomic electrons are restricted to certain discrete orbits via quantization of orbital angular momentum, and do not undergo the classical electromagnetic radiation process while they are in these orbits.
Bohr's model does make some incorrect predictions, although it gets the basic energy levels of hydrogen right; and it couldn't be extended to multi-electron atoms. People tried to fix it by introducing elliptical orbits and relativistic corrections (try a Google search on "bohr sommerfeld atomic model"), but in the end it was superseded by Schrödinger's quantum mechanics, plus the concept of "spin".
The electron is not changing its direction of movement?
Says who? In the classical picture of an orbiting electron, the electron's direction of motion is constantly changing.
13K
  • · Replies 20 ·
17K
  • · Replies 22 ·
