Thread Closed
how do you get rid of the SIN() function to solve for x?
Share Thread Thread Tools
Oct17-05, 04:22 AM   #1
i have x*sin(x/2) - 18/pi =0
and i need to solve for x..
how in the heck can i get rid of that sin() function? very confused.. any help will be appreicated..!
btw.. i need the answer ASAP! thanks alot guys
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Oct17-05, 04:41 AM   #2
Recognitions:
Homework Helper Homework Help
Can you use newton's method of approximation ?
Oct17-05, 04:42 AM   #3
i guess you can, could u explain how i would do that? and give me the answer for x=? thanks
Oct17-05, 05:08 AM   #4
Recognitions:
Quote by r3dxP
Here's a good description and an example of newton's method of approximation.
You will have to find the initial starting point, x0 -- the firstapproximation -- yourself.
To do so, make up a table of x and f(x) values, where f(x) = x*sin(x/2) - 18/pi.
Use values of x like: pi, 2pi, 3pi, ... until you get a change in the sign of f(x). That means that the curve, f(x), has crossed the x-axis, and therefore has been, at some point, equal to zero between the two x-values that gave the change of sign.
Take half-way between the two x-values as your first approximation, x0. You can get a closer approximation to x0 if you are familiar with interpolation. But that might be a bit of overkill at this point.
Oct17-05, 06:31 AM   #5
thanks alot. i just figured out that i can just graph it with ti83plus, then go2 calc and use the 'zero' function :) thanks for the help
Oct17-05, 01:47 PM   #6
Recognitions:
Even though you have the solution from the TI, here are additional comments that might be useful. Since this function is periodic, it will cross y=0 many times (see thumbnail). Newton's method works extremely well and converges very quickly on the solution, provided the starting guess of the solution is sufficiently close. Another option is bi-section, which is computationally much simpler, but takes longer to converge to the solution. Either method can easily be done w/ Excel.
Thread Closed
Thread Tools
Similar Threads for: how do you get rid of the SIN() function to solve for x?
Thread Forum Replies
how to use solve function in matlab in this case Math & Science Software 0
How to solve Bessel function Differential Equations 4
Basic Log Function, Solve for X Precalculus Mathematics Homework 4
Solve formulas containing the floor function Linear & Abstract Algebra 10
Using a Function to solve this? Calculus 5
