What are some invariants that can be used to distinguish between two spaces?
  • Context: Graduate
  • Thread starter Thread starter philosophking
    Topology
The discussion revolves around the concept of homeomorphism in topology, specifically how to determine if two spaces are homeomorphic or not. Participants explore methods for defining mappings between spaces and the implications of topological properties preserved under homeomorphism.
  • One participant questions how to show two sets are homeomorphic, specifically asking if defining a mapping is sufficient.
  • Another participant confirms that a mapping must be one-to-one and continuous, and its inverse must also be continuous.
  • A participant inquires about the method of parametrization to define a mapping between an interval and the real line.
  • One participant suggests using the function f(x) = 1/(x - a) + 1/(x - b) as a mapping example.
  • Discussion shifts to proving that two spaces are not homeomorphic, with participants suggesting that demonstrating differing topological properties could suffice.
  • Another participant notes that showing a contradiction from the assumption of homeomorphism is a valid method to prove non-homeomorphism.
  • Some participants discuss the difficulty of proving that certain properties are preserved under homeomorphism, while others assert that it is generally easier to prove specific properties are preserved.
  • Invariants such as homotopy groups and homology groups are mentioned as easy to calculate and useful for distinguishing spaces.
  • Participants discuss the characterization of smooth 2-folds and 3-folds, noting that certain invariants like genus and orientability can determine homeomorphism in 2-folds, while the situation is less clear for 3-folds.
Participants express differing views on the methods for proving homeomorphism and non-homeomorphism, with no consensus reached on the best approach. There are multiple competing ideas regarding the preservation of topological properties and the characterization of spaces.
Participants mention limitations in proving properties are preserved under homeomorphism and the challenges in generating a complete set of data to characterize spaces uniquely.
philosophking
One question I've had lately in my independent study of topology is the problem of how to show two sets are homeomorphic to each other. I am not sure how I would go about doing this in a general, or even specific case. One problem that wants me to demonstrate this is in Mendelson:
Prove that an open interval (a,b) considered as a subspace of the real line is homeomorphic to the real line.
Now, I know that a homeomorphism is a map where both it and its inverse are continuous, so I'm wondering if all that is needed to show two sets are homeomorphic is to simply define a mapping between the two. However, I don't know if this is right. Can someone please clarify?
Thanks.
Yes, that is pretty much it. The mapping has to be one-to-one so that an inverse can exist. The mapping has to be continuous and the inverse has to be continuous. So here the task is to define a mapping from the interval (a,b) to the entire real line [itex](-\infty,+\infty)[/itex].
How would you do that? I saw someone once parametrize to make it work, but I guess I just don't know how one would go about doing that.
What's with the LaTeX preview feature? It never seems to work for me.
Back to the matter at hand.
Hint: think tan(x) restricted to the domain (-pi/2 , pi/2).
Regards,
George
If you don't want to muck around mapping (a , b) onto (-pi/2 , pi/2), an easier example that I think works is f: (a , b) -> R given by
f(x) =1/(x -a) + 1/(x - b).
Regards,
George
Great, thanks a lot you guys. That was a big help. I guess it just depends on being creative in your map-defining.
How about showing that two spaces are not homeomorphic.
To do that you would have to show that one has a topological property that the other does not right?
By topological property I guess I mean any property of a topological space that is always preserved by homeomorphism...
Maybe its even harder to prove that any propety is always preserved by homeomorphisms... (I don't immediately see how to prove such a statement).
maybe I've just confused myself.
I guess a better way to prove two spaces are not homeomorphic would be to just assume they are homeomorphic and show that the existence of a homeomorphism between them leads to a contradiction.
Am I right? or does that first method work after all?
well, trivially, the answer is "yes" since "is a member of some equivalence class of topological spaces modulo homeomorphism" is a topological property. That is to say determining homeomorphism type and showing they are not equivalent would obviously do.
no, it is usually easy to prove certain properties are always preserved by homeomorphism. What is hard is generating a complete set of data that uniquely characterizes the space and is not as difficult as working out every possible homeomorphic image.
your "two methods" appear to be the same: show that they have some different invariants under homeomorphism (that would be the contradiction). there are some easy to calculate invariants: homotopy groups, homology groups etc.
In the case of smooth (connected compact) 2-folds then the genus and orientability determine the space up to homeomorphism. That is every compact connected surface is homeomorphic to either a torus with n holes (n in N) or a torus with n holes and a mobius cap stitched in. (equivalently the fundamental group determines it).
in the case of 3-folds (things that look locally like R^3) then we do not know what data is sufficient to characterize them. see eg the poincare and geometrization conjectures.
  • · Replies 17 ·
  • · Replies 17 ·
