What Challenges Arise in Calculating pH Changes in Buffer Solutions?
  • Thread starter Thread starter dekoi
    Equilibria
This discussion focuses on the challenges of calculating pH changes in buffer solutions, specifically involving 0.10 M NH3 and 0.10 M NH4+. The participants detail the equilibrium reaction and the calculations for pH, pOH, and the impact of adding hydrochloric acid (HCl) to the buffer. The discussion also addresses the acidity of rantidinium chloride in Zantac and the hydrolysis behavior of various ions, concluding that hydrolysis occurs for weak acid conjugate bases while strong acid conjugate bases do not undergo hydrolysis.
  • Understanding of buffer solutions and their components (NH3 and NH4+).
  • Knowledge of acid-base equilibria and the Henderson-Hasselbalch equation.
  • Familiarity with hydrolysis concepts and the behavior of conjugate acids and bases.
  • Basic skills in stoichiometry for calculating moles and concentrations.
  • Study the Henderson-Hasselbalch equation for buffer calculations.
  • Learn about the effects of strong acids on buffer systems.
  • Research hydrolysis reactions of various ions, focusing on weak acids and bases.
  • Explore the properties of rantidinium chloride and its implications in pharmacology.
Chemistry students, educators, and professionals in pharmaceuticals or analytical chemistry who are involved in buffer solution calculations and acid-base chemistry.
dekoi
1.) What is the pH of a buffer solution that is 0.10 NH3 and 0.10 NH4+? What is the pH if 12mL of 0.20 M hydrochloric acid is added to 125 mL of buffer?
For the first part, i figured that NH3 is the base and NH4+ is the conjugate acid. Therefore, the equil. reaction is NH3 + water --> NH4+ OH-. Using the given concentrations, i found Kb, pOH, and then Ph.
For the second part, I'm unsure. I figured out the moles of NH3 and NH4+ by multiplying each molarity by 0.125 L. Then i did the same for H3O+ ion (formed by HCl) using 12mL as the volume. However, the problem appears as I'm unsure whether the addition of HCl will depleat the amount of NH4+ or NH3. Should i subtract the moles of the hydronium ion from the moles of NH3 and add it to NH4+? Or the other way around?2.) A chloride salt (rantidinium chloride) is presnet in Zantac. Should a solution of rantidinium chloride be acidic, basic, or neutral?
This is my logic: Since chloride ion forms an acidic solution with Hyrdogen (that is, its a conjugate base of a strong acid), then the solution should be acidic. But i need to consider rantidinium as well, and see whether that is an anion of a strong base, in which case the solution would be neutral. But how do i do that?
3.) I have to determine whether hydrolysis would occur with the following:
a.) NO3-
b.) OCl-
c.) NH2NH3+
d.) Br-
a.) Since NO3- is a conjugate base of a strong acid, no hydrolysis would occur.
b.) Since OCl- is a conjugate base of a weak acid (HClO), hydrolysis does happen.
c.) I have no idea!
d.) Since HBr is a strong acid, no hydrolysis happens.
My questions are: i.) Why does hydrolysis not happen when an ion is a conjugate acid/base of a strong acid/base? and ii.) Part C.Thank you.
Why do you think you will get here different answer from the one you got at chemicalforums?
There is one chemistry only ;)
