Is Gravity Real? Understanding the Evidence for Gravity's Existence
  • Context: High School
  • Thread starter Thread starter DaveMan
    Gravity Proof
The discussion revolves around the nature of gravity, its existence, and the evidence supporting it. Participants explore various aspects of gravity, including its effects on massless particles like light, the relationship between gravity and time, and theoretical concepts such as shielding gravity.
  • Some participants describe gravity in terms of Newtonian physics as an attraction between massive bodies, while others reference general relativity's concept of spacetime curvature.
  • There is a discussion about how gravity affects massless particles like photons, with some arguing that gravity acts on all objects, regardless of mass.
  • A participant mentions historical evidence for gravity's effects, such as light bending during a solar eclipse and the concept of gravitational lensing.
  • Some participants express confusion about the implications of gravity on time, referencing experiments with clocks in different gravitational fields.
  • There are hypothetical questions raised about the possibility of shielding gravity and discussions about the existence of gravitons.
  • One participant proposes an analogy between gravity and acceleration, suggesting that gravity's effects can be conceptualized similarly to those of acceleration.
Participants express a range of views on the nature of gravity, its effects, and related concepts. There is no consensus on several points, including the existence of gravitons and the possibility of shielding gravity.
Participants mention various experiments and theoretical ideas, but there are limitations in understanding and definitions, particularly regarding the nature of massless particles and the implications of gravity on time.
DaveMan
Could someone tell me what gravity is, and what is the proof that gravity exists?
Inb Newtonian physics gravity is the attraction between two massive bodies, in general relativity it is the curvature of space-time. The proof that it exists is the fact that when you posted the above post you were not floating upside down.
gravity does not only exist as a pull from large objects however all objects pull on one another.
:wink:
I don't get it, how can light with no mass, or photons with no mass be affected by gravity?
It is that gravity acts on all things including things with no mass?
Gravity
Well we know know light as both particle and wave or some would call it a "wavicle". The particle aspect of light allows gravity to play a role in affecting it. That's a simple way to put it.
It was proven in the early 20th century during a solar eclipse off the coast of Africa when the gravity of the sun distorted the position of nearby stars.
Also look up information on Gravity Lenses. A lot of deep space photography utilizes the gravity lensing effect. Very cool stuff.
Einstein's theory of general relativity describes gravitation as a result of the curvature of spacetime. All objects, even massless photons, move along the straightest possible lines in this curved space. The straightest possible lines in a curved space, however, and not "straight" like lines drawn on a plane.
- Warren
Yes. This is why gravity is referred to as the only "universal" interaction: it acts on everything.
if Time is viewed as an interaction, couldn't this also be a universal determinate?
No, time is shown by experimentation to be variable.
i don't understand the difference, what are some experiments to show this?
One of the simplest done is with two identical clocks. One is put into orbit around the earth, the other stays on the ground. The clock in orbit sends a signal to a computer on the ground which compares it to the clock on the ground. The clock in orbit loses time when compared to the clock on the ground. This fact (and correcting for it) is of the utmost importance in making the GPS system work.
Experiments have also been done on clocks on towers: gravity affects the rate of the passage of time as well.
Despite how many times i hear about that. (Gravity's effect on time) I still have trouble comprehending how it even begins to work...
Any links on it as I have no clue what to search for.
Is it so much easier to understand how gravity affects something with mass?
Yes, I would say that it is. Something that is matter is imagined easier if it has a mass, therefore it is a real thing or object. It is hard to understand how massless objects or the concept of photons exist. And gravity, which acts on everything; so does it also act on nothing? (or a thing with no mass?)
Oh yeh, I agree. A hypothetical question...
In a sealed room is it possible to take the gravity out of the room, by using no external factors. - eg sucking the gravitons out of the room. and what would happen if it were possible?
Originally posted by Ambitwistor
You can shield a room from electromagnetic effects, but you can't shield a room from gravitational effects.
Wasn't there some talk of BEC's shielding gravity? Thought I heard somrthing along those lines recently, though it still strains my credulity.
The effects of gravity are similar to the effects of accelleration. If an object is falling , it will feel no acceleration. You could imagine that if Earth were flat and were constantly accelerating, you would feel the same effect as gravity. I personaly don't believe in the existence of gravitons. I believe that, mabye gravity is something to do with space-time bending from energy so only particles with mass can overcome it, but this requires a constant acceleration. If there is nothing holding the object up(eg. a falling stone) it will have noway to overcome the pull. Imagine a vacuum cleaner constantly sucking in space-time in all directions. With light, it isn't actually being pulled in from gravity but rather, there is nothing accelerating the light so it stayes on the same path of space time.
I don't think this is what most people believe, but I bet it is more accurate.
Maybe you're thinking about the *ahem* work (?) of Eugene Podkletnov?
http://www.wired.com/wired/archive/6.03/antigravity_pr.html
- Warren
Given what I typed above, it would be impossible to shield grvaity.
If you believe in the existence of a graviton, then it is possible that mabye you could shield, or redirect this flow.
  • · Replies 32 ·
  • · Replies 22 ·
