Proving (-1 + i)7 = -8(1 + i) Using Polar Form: Complex Number Question
The discussion revolves around proving the equality (-1 + i)⁷ = -8(1 + i) using polar form in the context of complex numbers.
  • Participants discuss converting the complex number -1 + i into polar form, including calculating its magnitude and angle. There is mention of using the polar form formula and the implications of raising a complex number to a power.
Some participants have provided insights into the polar form conversion and its components, while others are seeking further clarification on specific calculations. The discussion is ongoing with multiple aspects being explored.
Participants reference the need to use polar form specifically for this proof, indicating a focus on understanding the method rather than arriving at a final answer.
Reshma
This is a simple problem. Show that:
where i = sqrt(-1)
I'm able to prove this result by expanding the bracket:
[(-1 + i)3]2(-1 + i)
But please help me prove this using the polar form.
where i = sqrt(-1)
Okay, PUT it in polar form! Polar form is [itex]r (cos(\theta)+ isin(\theta))[/itex] where r is the "magnitude" of the complex number (distance from 0) which is [itex]\sqrt{(-1)^2+ 1^2}= \sqrt{2}[/itex] for -1+ i and [itex]8\sqrt{2}[/itex] for -8(i+1). You can get [itex]\theta[/itex] by using [itex]\theta= arctan(\frac{Im}{Re})[/itex] but you should be able to see simply by plotting the points. -1+ i corresponds to (-1,1) in the plane so the angle is [itex]\frac{\3pi}{4}[/itex]. -(1+i)= -1-i corresponds to (-1, -1) so the angle is [itex]\frac{5\pi}{4}.[/itex].
The seventh power of a complex number corresponds to taking the seventh power of r and multiplying [itex]\theta[/itex] by 7.
Can you write z = -1 + i in polar form? What is the magnitude?
I see Ivy has this handled.
Thanks, HallsofIvy! That was easy!
  • · Replies 20 ·
  • · Replies 21 ·
