| Thread Closed |
normal subgroups, isomorphisms, and cyclic groups |
Share Thread |
| Oct30-05, 06:38 PM | #1 |
I'm really stuck on these two questions, please help!
1. Let G={invertible upper-triangular 2x2 matrices} H={invertbile diagonal matrices} K={upper-triangular matrices with diagonal entries 1} We are supposed to determine if G is isomorphic to the product of H and K. I have concluded that this is true, but I'm having trouble proving it. I need to show three things: (1)H,K are normal subgroups of G; (2)the intersection of H and K is the identity; (3)HK=G I can do (3), I can see that (2) is true (though I haven't written it up formally yet), and I can show that K is a normal subgroup of G. I'm having trouble showing H is a normal subgroup of G. I tried finding a homomorphism between G and K and showing the kernal of that homomorphism is H (this is how I showed K is normal), but I can't find a function that works. I've also tried showing that there are elments g in G and h in H such that ghg[tex]^-^1[/tex] is in H, but to no avail. So I'm stuck. 2. Prove that the product of two infinite cyclic groups is not infinite cyclic. So far, this is what I have: Let H and G be two infinite cyclic groups. Let H be generated by h and G by g. Also, the product of G and H, GxH={(g,h) such that g is in G and h in H}. So I need to show there is no element (a,b) in GxH suth that (a,b) generates GxH. That is, show there is no (a,b) in GxH such that (a[tex]^n[/tex],b[tex]^n[/tex])=(g[tex]^i[/tex],h[tex]^j[/tex]) for any i,j. This is where I'm stuck. |
| Oct31-05, 05:35 PM | #2 |
Recognitions:
Suppose (a,b) generates GxH. Then for all g in G, h in H, there is an m such that (a,b)m = (g, h). In particular, there must be some m such that this holds when g = an and h = bn+1 for some n, so: (a,b)m = (an, bn+1) (am,bm) = (an, bn+1) (am-n,bm-n-1) = (eG, eH) So either one of a, b is the identity, or both m-n and m-n-1 is zero. Clearly, the second option is impossible. But if one of a, b is identity, you can easily show that (a,b) won't generate the group. |
| Oct31-05, 06:05 PM | #3 |
Hrm. Just to make sure I haven't made a silly mistake, H and K are both abelian groups, right?
| Oct31-05, 06:16 PM | #4 |
Recognitions:
They are abelian subgroups, but this doesn't help in showing that they're normal. Consider An for n > 5. The group is simple, thus has no non-trivial normal subgroups, but any subgroup generated by a single element is of course abelian.
| Oct31-05, 06:26 PM | #5 |
It helps for showing something else though!
| Nov1-05, 05:24 PM | #6 |
Recognitions:
What else needs to be shown?
| Nov1-05, 05:40 PM | #7 |
Well, if H and K are both abelian groups, then so is HxK!
| Nov1-05, 06:58 PM | #8 |
Recognitions:
Why do we need to know that?
| Nov1-05, 07:03 PM | #9 |
Well, any group isomorphic to an abelian group must be abelian, right?
| Nov1-05, 08:02 PM | #10 |
Recognitions:
Yes, I still don't see why it's relevant. There's a theorem which states that if H and K are normal subgroups of G, H and K intersect only at identity, and HK = G, then G is isomorphic to H x K. Why does he need to know anything about them being abelian? My book actually states a slightly different theorem, replacing the condition that H and K be normal with the condition that every element of H commute with every element of K. However it can be proved that if H and K are normal, then every element of H commutes with every element of K. At no point, however, do you need to consider whether or not H or K are abelian.
| Nov1-05, 08:17 PM | #11 |
Well, G isn't abelian, and thus cannot be isomorphic to HxK.
| Nov2-05, 06:04 PM | #12 |
Recognitions:
I see the problem. I erred when I said that:
No, what you have to do is show that for ALL h in H and for ALL g in G, ghg-1 is in H. This can be shown by a simple computation. H is not even normal. I assumed it was because I thought the original poster had concluded that it was true, and figured that it was. If H were normal, then a simple computation would have sufficed to prove it. In fact, H is not (which is why the theorem doesn't apply), and a simple computation is enough to show this. Of course, showing H is not normal is unnecessary (and insufficient) to show that G is not isomorphic to H x K, what Hurkyl said is perfect. |
| Thread Closed |
Similar discussions for: normal subgroups, isomorphisms, and cyclic groups
| Subgroups of Quotient Groups | Linear & Abstract Algebra | 0 | ||
| Fintie Groups; Subgroups | Precalculus Mathematics Homework | 14 | ||
| groups/normal subgroups | Calculus & Beyond Homework | 18 | ||
| Intersection of cyclic subgroups | Linear & Abstract Algebra | 2 | ||
| Proof Using Def. of Groups and Def. of Subgroups | Introductory Physics Homework | 3 | ||
