Convert g*cm^2 to kg*m^2: Explanation & Help
The discussion revolves around converting a moment of inertia value from g*cm² to kg*m². Participants are exploring the appropriate method for unit conversion, particularly focusing on the implications of squaring the conversion factors.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to understand the conversion process and questions how to account for the squared dimensions in the conversion. Some participants discuss the general technique of setting up conversions as multiplication of fractions and express confusion about applying this method to squared units.
Participants are actively engaging with the conversion process, with some providing guidance on squaring conversion factors. There is a recognition of the need for clarity in setting up the calculation, particularly for squared quantities, but no consensus has been reached on the exact setup for the original poster's specific case.
The original poster mentions the urgency of the conversion due to an online assignment with limited attempts, indicating a constraint on their ability to make errors in the calculation.
azure.hubris
Hello,
I need to convert a moment of intertia value given in g*cm^2 to kg*m^2, and was hoping someone could give me a run down of the method behind these kind of conversions. Do I simply assume that since g to kg is a factor 0.001 and cm to m is 0.01, that I can apply a factor of 0.00001 to my initial value? I feel that that method would be fine for say, g*cm to kg*cm, but I'm not sure how to account for the squared dimension. Any help/explanation would be appreciated. Thanks.
In general when converting units set your quantity to be converted and your conversion factor up as a multiplication of fractions. For example from m/s to cm/s
[tex]10 \frac m s * 100 \frac {cm} {m} = 10*100 \frac m s * \frac {cm} {m} = 1000 \frac {cm} s[/tex]
Note that in this example the m in the numerator cancels the m in the denominator, leaving only cm in the numerator.
okay, i see what you mean, I've used that technique before, but the confusion came from two places for me.
1) that I'm dealing with a squared quantity, so would the conversion be 1000cm^2/m^2?
2) that the it's g*cm^2, rather than g/cm^2, leaving me wondering how to actually set up the calculation.
i'm sure it's quite obvious how to do this, but the way i set it up, the units don't cancel out. i need to be certain of this conversion before i can begin to do the problem, since it's for an online assignment for which i have only one attempt. could you possibly lay out how you'd set it up for the case of my calculation? i know it's not usually acceptable to 'give' the solution away in this forum, but the physics of the problem are not a concern, just this one calculation. okay, thanks again for your help.
The method is the same just square the conversion factors. So
[tex]10m^2 = 10 m^2 * (100 \frac {cm} m)^2 = 10 * 10^4 m^2 \frac {cm^2} {m^2} = 10^5 cm^2[/tex]
thanks for your help!
