Projectiles questions-Rush!
by PreciousJade
Tags: projectiles, questionsrush
PreciousJade
PreciousJade is offline
#1
Nov1-05, 09:57 PM
P: 5
Projectiles- Physics11.
This is part of my lab, and i really can't figure this out
So I need some help .,
Here are the questions ::
*Assume you can throw a baseball 40 meters on the earth's surface.How far could you throw that same ball on the surface of the moon, where the acceleration of gravity is one-sixth what it is at the surface of the earth??
*AND will the acceleration due to gravity be different at 1000 meters above the surface of the Earth?
please i need help
Thank you sooo much..
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
Pengwuino
Pengwuino is offline
#2
Nov1-05, 10:03 PM
PF Gold
Pengwuino's Avatar
P: 7,125
Well for the first part, you can use the kinematic equations to determine how fast you actually threw the ball and plug this velocity into a new kinematic equation with hte moon's gravity in place of the earth.
PreciousJade
#3
Nov1-05, 10:19 PM
P: 5
Which question should i use?
Would i consider Initial Velocity at 0m/s
or the Final Velocity at 0m/s?
If the case is when you throw the ball ?
Thank you
PreciousJade
#4
Nov1-05, 10:40 PM
P: 5
Thank you
Pengwuino
#5
Nov1-05, 10:49 PM
PF Gold
Pengwuino's Avatar
P: 7,125
The initial velocity at 0m/s? You mean x=0. Use x=0 i suppose because on a level surface with no friction, it will have the same speed at the end and at the beginning. You do this for the case when the ball is thrown on earth.
verty
verty is offline
#6
Nov2-05, 09:10 AM
HW Helper
P: 1,373
I don't see any other way to help than to show how I would approach this. Gravity only determines the time the ball remains in the air:
s = v_h*t
t = (v_v-u_v)/g
Go from here.
Register to reply
Related Discussions
Getting a 2nd BS or rush to get a masters? Academic Guidance 8
Supposedly very easy questions dealing with projectiles, equilibrium, etc. Introductory Physics Homework 12
Rush Limbaugh Arrested General Discussion 12
Ah, rush hour General Discussion 8
Is Rush Limbaugh really a stoner? General Discussion 24
