Calculating Work Done by Air Resistance on a Thrown Ball
The discussion focuses on calculating the work done by air resistance on a 0.63-kg ball thrown vertically with an initial speed of 14 m/s, reaching a height of 8.1 m. The gravitational work was calculated as -50 J using the formula m*g*(delta y). The total work done was determined to be -62 J using the Conservation of Energy Work (CEW) theorem. Ultimately, the work done by air resistance was found to be -12 J, with a clarification that the energy lost due to air resistance is 11.7 J.
  • Understanding of Newton's laws of motion
  • Familiarity with the Conservation of Energy Work theorem
  • Knowledge of gravitational potential energy calculations
  • Basic principles of kinetic energy
  • Review the Conservation of Energy principles in physics
  • Study the effects of air resistance on projectile motion
  • Learn about the relationship between kinetic and potential energy
  • Explore advanced calculations involving work and energy in different contexts
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of projectile motion and the effects of air resistance.
Elysium
Hi, I'm having problems with this question:
2. A 0.63-kg ball is thrown straight up into the air with an initial speed of 14 m/s. It reaches a height of 8.1 m, then falls back down. Assume that the only forces acting are those of gravity and air resistance and calculate the work done during the ascent by the force of air resistance. (Hint: Use the CWE theorem and the potential energy associated with the gravitational work.)
ok first I determined what work that gravtity does which is m*g*(delta y) which in this case is -50 J
I then used the CEW theorem equation using the velocities to find the total work done: (sigma W) = 1/2 m (v^2 (final) - v^2(initial)) which is -62 J
Last part is that I used the relationship between the work of gravity and the total work (sigma)W = W of gravity + Work of air resistance. I got -12 Joules for air resistance. I don't know but I feel like I got something wrong here. Can anyone help me out?
Well, the difference between the kinetic energy at the bottom and the potential energy at the top will be the amount lost due to air resistance.
E_a = (1/2)mv^2 - mgh = 61.7 - 50
= 11.7J
W_a = E_a
= 11.7J
I don't know the method you have used.
Edit: Work is a scalar I see.
