Calculate Radius of Wire in Air Wedge Formed by Glass Plates
  • Thread starter Thread starter U262241
    Air Wedge
The problem involves calculating the radius of a wire that creates an air wedge between two glass plates, illuminated by light of a specific wavelength. The scenario includes observing dark fringes and requires understanding the relationship between the fringe count and the thickness of the air gap.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss various formulas and approaches to relate the number of dark fringes to the thickness of the air gap. There are questions about the correct application of the formula, including whether to adjust the fringe count and how the light paths contribute to the observed fringes.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the assumptions behind their calculations. Some have provided calculations based on their interpretations, while others are seeking clarification on the underlying concepts.
There is a debate about the correct value of the fringe count to use in calculations, as well as the implications of the wavelength on the results. Participants are also considering how the geometry of the setup affects the observed fringes.
U262241
An air wedge is formed between two glass plates separated at one edge by a ver fine wire. When the wedge is illumindated from above by 688 nm light, 29 dark fringes are observed. Calculate the radius of the wire. Show answer in micro meters
I have tried many different things with this problem and cannot come up with the correct answer. Here is the last thing I did. Since 39 dark fringes are seen; 39 light fringes will also be seen. Where t=0 will be the first dark fringe. Which means fringe 78 is a light fringe, which is right next to the wire separating the two glass plates. The formula is:
t = [((m - 1/2)*lamda) / 2] * 1e+6 micro m/m
This will give the diameter of t. Divide the diameter by 2 to get the radius. Unfortunately, this does not give the correct answer. What am I doing wrong. The answer I came up with is 13.158 micro meters.
Each time the fringes go from dark to light to dark again, by what fraction of a wavelength has the air gap increased?
Should it be +1/2 instead of -1/2?
No no, forget the freakin' formula for a second. Do you know how these fringes show up? THe two paths of light, one slightly longer, etc? Each time you get to another dark fringe, how much farther has the second ray of light traveled?
i using the formula with : 2t = n (w)
**P/s : w = wavelength , t = thickness
regarding ur ques --> w= 688nm , n (dark) = 29
hence,
t = (29*688nm) / 2
= 9.976 micro meter
Since the ques need ans in radius, therefore
t / 2 = 9.976/2
= 4.988 micro meter ( Ans )Done! Is it correct??
am i correct to say that since for the 1st dark fringe, we consider n=0, thus the value of n should be 28 instead of 29 ?
hence, making it:-
2 (t) = (28) (688*10^-9)
where t = 9.63 micrometer
and the radius is 4.82 micrometer ?
10K
14K
10K
