What is the Flux through a Square Loop with a Current-Carrying Wire?
  • Thread starter Thread starter WhoWeAre
    Flux Loop Square
The discussion revolves around calculating the magnetic flux through a rectangular loop positioned beneath a current-carrying wire. Participants are examining the relationship between the dimensions of the loop and the resulting flux formula, particularly questioning the absence of the loop's height in the final expression.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are exploring why the height of the loop does not appear in the flux formula, despite its presence in the area calculation. There are discussions about integrating variables and the implications of using Ampere's Law in this context.
Several participants are actively questioning the assumptions behind the formula and the integration process. There is a mix of attempts to clarify the relationship between the dimensions of the loop and the magnetic field, with some suggesting alternative approaches to the integration.
Participants are working under the constraints of a homework problem, which may limit the information available for discussion. The original poster expresses confusion about the application of Ampere's Law and the integration of area versus distance variables.
WhoWeAre
I'm confused. Here is the problem I'm working on. Imagine a long, straight wire crossing the screen or page horizontally. It is carrying a current i. Now imagine a rectangular loop underneath the wire a distance of d away. The loop has a height of a and a width of b. I am supposed to find the the flux that passes through the loop. i is a constant, as are b, a, and d. My confusion arrises from that fact that the flux = ((mu(naught)*i*b)/2*pi)(ln((d+a/a)). Since ampere's law is (flux)= integral(B dot dA) (where B is the B of the wire), shouldn't there be an a in the formula for flux? I know that there shouldn't be, but not why. Could some one please help me?
You HAVE an "a" in your correct result for flux (2 of them!)
Do you mean, why Doesn't Ampere's general law label the Area
as Length x width ? well, LW doesn't have an "a" in it either!
More to the point, somebody will want to use A = pi R^2 ...
Can you try to be a little more specific?
I should have asked:
Why is only the width of the loop included in the final formula. Shouldn't there be a (width*height) in the final formula?
You need to write B in terms of d and a because it's value depends on the distance from the wire, when you evaluate the resulting integral you don't get any b*a
your final result is proportional to I*b*ln[(d+a)/a]
those "a"'s do NOT cancel! (integral of dxdr/r ...)
Actually it's been awhile since I've done any problems like this, but it seems to me that it would, instead of re-writing B, be better to make a change of variables, from dA to dx where x is the distance from the wire then integrate "toward" the wire.
I don't see how to do that. It doesn't seem like I need to do that because I am integrating over a. That should take care of B in terms of d and a. But what happens to dA in Ampere's Law. Does it become just A because it is constant or does something else happen to it?
Oh, I see, I think. Are you saying that dA is equal to b*dx, where dx is the height of the loop?
you are NOT integrating over "a"!
you're integrating dr, from d to (d+a).
"a" is a constant parameter, labeled in the diagram,
while "r" is the variable of integration.
The functional form of Ampere's Law, in cylindrically symmetric situations,
would usually be written in terms of radial distance "r":
proportional to dxdr/r , where x is the traditional horizontal direction.
Right. I'm saying that it seems to me that the area of the loop (b*a) should be in the final formula, but it is not. Only the width of the loop (b) is. Why?
do you know how to integrate dr/r?
hint: do you remember the derivative of ln[r]?
Ya, that's pretty easy integral. But I guess you don't understand my question. Oh well, thanks for try'in guy.
Later
the "a" is there, inside of the logarithm.
integral (I dA / r) = I * integral( dx dr / r) = I X integral ( dr / r)
where "X" has to be evaluated at "x" and at "x+b" .
Since one of the dimensions of dA is in the denominator,
why aren't you surprized that that dimension DOES show up in the end,
rather than cancelling out.
I'm doing a similar question to this. From lightgrav's method, I got the right answer. But I don't understand why we seem to be doing a line integral instead of a surface integral. How did you change from integrating dA (surface integral) to dr (line integral)?
9K
