How do you prove the force between two conductor plates is F=q^2/2eA?
The discussion revolves around the derivation of the force between two conductor plates, specifically the expression F=q^2/2eA. Participants explore the assumptions regarding electric fields generated by conducting plates and the implications of charge distribution in the presence of dielectrics.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the derivation of the force using electric field equations and question the assumption that the electric field behaves as if generated by a uniform plate. There is also exploration of work-energy principles and the application of Gauss's Law in different contexts.
The discussion is active, with participants expressing confusion about the application of Gauss's Law and the treatment of charge distribution on conductor plates versus insulators. Some have offered links for further reading, while others reflect on their understanding of the concepts involved.
There are mentions of inconsistencies in applying Gauss's Law and the effects of dielectrics on electric fields, indicating that participants are grappling with the nuances of these concepts. The original poster and others express uncertainty about the assumptions made in deriving the force equation.
brentd49
How does one prove that the force between two conductor plates is F=q^2/2eA, where e=epsilon.
If I use F=qE. Where the electric field is generated by one of the conducting plates: E=q/eA, then F=q^2/eA.
I think what the answer assumes is that the E-field is from a uniform plate (insulator): E=q/2eA. In that case, F=q^2/2eA, which is the correct answer. But how can you make that assumption when obviously two conductor plates will have all their charge on the surface facing the other plate?
^bump
I must have some concept wrong, because they use that equation again for the conductor when they are caculating the electric field inside a conductor with a dielectric, i.e. E=qf/2eA+qf/2eA-qi/2eA-qi/2ea (where qf=free charge on conducting plate, and qi=charge bound to dielectric).
I am a little unsure how they are coming up with that 1/2, because in my book they derived the Electric field using surface charge density (with Gauss' Law, of course), and the result is E=o/e (surface charge density/epsilon)--no 1/2. I suppose if you are dealing with charge and not charge density, then an excess charge 'q' will distribute q/2 on each surface.
So, I am now completely lost. Because I thought the influence of another charged plate would draw all of the 'q' to one surface, even with a dielectric.
I understand now, thanks. I think Halliday, Resnik could have done a better job, though.
Yeah, when I first studied EM, it was not so intuitively obvious to me, despite the fact that the textbooks and professors claimed it so.
Anyway, it comes down to the charge distribution and Gauss's law.
See if this helps.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html#c1
In the case, where there are equal and opposite charge densities, the contribution to the electric field must be equal, so that each charge distribution contributes
E = [itex]\frac{\sigma}{2\epsilon_o}[/itex], and the combined field is
E = [itex]\frac{\sigma}{\epsilon_o}[/itex]
All textbooks seem to use the same example, and I think they could all do a better job.
I looked at the links, but I'm still having a little trouble..
(1) There seems to be an inconsistency when applying Gauss's Law. When they calculate the electric field between two insulated sheets they use superposition to find the net electric field. But for two conducting sheets, the derivation does not require superposition. In both cases the electric field is the same (E=q/eA), but if superposition was used for the conductor then E would be twice as large (two sheets), E=2q/eA. EDIT: This could be because they keep interchanging the charge density based on the situation--this isn't helping.
(2) Does a dielectric block the external electric field between two capacitor plates? Because the book solution for the electric field between a capacitor with a dielectric is: E=qf/2eA+qf/2eA-qi/2eA-qi/2ea (where qf=free charge on a conducting plate, and qi=charge bound to dielectric). The qf/2 implies the charge distribution is divided on the two halves of the conducting plate, whereas typically all the charge is on the surface facing the other plate.
  • · Replies 26 ·
