Anyone see where I messed up on finding the current?
  • Thread starter Thread starter mr_coffee
    Current
The discussion revolves around a problem involving two parallel wires carrying equal currents and the magnetic field generated between them. Participants are trying to determine the direction of the currents and calculate the necessary current to achieve a specified magnetic field strength.
  • Participants are questioning the distance used in calculations and whether the currents should be in the same or opposite directions. There is also discussion about how each wire contributes to the magnetic field and whether the fields cancel or add together based on the current direction.
Some participants have provided guidance on checking the distance used in the calculations and the contributions of both wires to the magnetic field. There is an ongoing exploration of how the direction of the currents affects the resultant magnetic field.
Participants are working under the constraints of the problem, which specifies the magnetic field strength and the distance between the wires. There is uncertainty regarding the correct interpretation of the setup and the calculations involved.
mr_coffee
I'm not sure what I'm doing wrong...
Two long straight wires are parallel and 5.0 cm apart. They are to carry equal currents such that the magnetic field at a point halfway between them has magnitude 320 µT.
(a) Should the currents be in the same or opposite directions?
same
opposite
correct check mark
(b) How much current is needed?
wrong check mark A
Here is my work:
http://show.imagehosting.us/show/916283/0/nouser_916/T0_-1_916283.jpg
Thanks!
check "r." What is this distance supposed to be?
Consider that one wire should be producing HALF of the field...
I Agree with Chi... Check your r value.
I did what i think u guys ment...since its only half way, I took half the distance .05m, which is .025, and i plugged it into the formula:
(B*2PI*r)/u = i;
i = (320E-6)(2*PI*(.025)/1.26E-6
i = 39.89 which was also wrong
is that what u guys ment?
don't you have two wires? Both contribute the the B-Field.
So is the mangintude of the b field just multiplied by 2? or would it be 0? because they are producing a repulisve force on each other, and the currents are equal
Part of the question is to decide which way the currents must run, parallel or antiparallel. One way will cancel the fields, the other way will add up the fields. Use the right hand.
  • · Replies 23 ·
  • · Replies 34 ·
