The discussion revolves around the functionality of the "Line In" and "Microphone" inputs in Windows XP, particularly in the context of using Skype for phone calls. Participants explore the configuration options available for selecting the "Line In" input instead of the default "Microphone" input.
- Technical explanation, Debate/contested
- One participant inquires about configuring Windows to use the "Line In" input for Skype calls instead of the "Microphone" input.
- Another participant suggests that it is possible to use the "Line In" input by unmuting it, implying that it should work if configured correctly.
- A different participant explains that Windows can only listen to one input port at a time and describes how to check which input is currently selected in the volume properties.
- The original poster expresses frustration that their attempts to select "Line In" are overridden automatically when making a call, indicating a potential limitation or issue with the software.
- A later reply humorously comments on the situation, suggesting a general dissatisfaction with Windows' handling of input selection.
Participants do not reach a consensus on the issue. While some suggest that "Line In" can be used, the original poster's experience indicates that there are complications preventing it from functioning as desired.
There are limitations regarding the automatic switching of input selections during calls, which remains unresolved. The discussion does not clarify whether this behavior is a software bug or a feature of Windows XP.
