Thermal Expansion Problem: Help Solve Clearance Issue
The thermal expansion problem involves a brass rod with a radius of 0.5 cm fitting into a copper sheet with a clearance of 0.010 mm at 20 degrees Celsius. The equation for thermal expansion is Δx = α(T−T₀)R, where α is the coefficient of linear expansion, T is the temperature, T₀ is the initial temperature, and R is the radius. By substituting the values, the temperature at which the clearance becomes zero is calculated as T = 293 + (20 x 10^-3 m / α), with α being the coefficient of linear expansion for brass and copper.
  • Understanding of thermal expansion concepts
  • Familiarity with the coefficients of linear expansion for materials
  • Basic algebra for solving equations
  • Knowledge of unit conversions (cm to m, mm to m)
  • Research the coefficients of linear expansion for brass and copper
  • Learn about thermal expansion equations and their applications
  • Explore unit conversion techniques for precision in calculations
  • Study real-world applications of thermal expansion in engineering
Engineers, physics students, and anyone involved in materials science or mechanical design who needs to understand thermal expansion effects in practical applications.
kris24tf
Thermal Expansion Please Help!
I have a Thermal Expansion problem that I am having trouble with...
It goes :
A brass rod has a circular cross section of radius .5 cm. The rod fits into a circular hole in a copper sheet with a clearance of .010 mm completely around it when both it and the sheet are at 20 degrees C. At what temperature will the clearance be zero?
I know I have to use Area of Expansion here, but I am not sure which version to use. I knwo to convert .5 cm to .005m and .010mm to 10m. I also know that delta T equals T-293=20-293=-273K. I do not know how to develop the equation. Any assistance would be appreciated, although I will warn that I do not do well with written explanations as well as numerical ones...
Thank you! The equation for the thermal expansion of an object with a circular cross section is:Δx = α(T−T₀)Rwhere α is the coefficient of linear expansion, T is the temperature of the object, T₀ is the initial temperature, and R is the radius of the circular cross section. Using the given values, we can solve for T:0.010 mm = α(T−293)0.005 mT = 293 + (0.010 mm / (α 0.005 m))T = 293 + (10 x 10^-3 m / (α 0.005 m))T = 293 + (20 x 10^-3 m / α)Therefore, the temperature at which the clearance will be zero is 293 + (20 x 10^-3 m / α), where α is the coefficient of linear expansion for brass and copper.
