ohwilleke
- 1,636
- TL;DR
- A new paper from two MIT profs purports to explain the parameters of the CKM and PMNS matrixes with values that minimize quantum entanglement, a novel explanation for the value.
I've never seen anyone reach this remarkable insight before, and it is indeed very tantalizing. This is huge if true and comes from seemingly credible authors. The modest language in which the claim is made is also encouraging.
The authors note in the body text that:
Are there any obvious flaws in their analysis? (The abstract and citation are below).
The paper's literature review does note one prior paper making a similar analysis:
Ref. [27] is A. Cervera-Lierta, J. I. Latorre, J. Rojo and L. Rottoli, Maximal Entanglement in High Energy Physics, SciPost Phys. 3 (2017) 036, [1703.02989].
Footnote 6 of the main paper is also of interest and addresses the fact that using only a one-loop calculation they get a value of 6º for a parameter whose measured value is 13º.
PF Meta Considerations
I weighed whether it made more sense to make this post in BSM v. HEP forums here, and concluded that BSM was more appropriate because the minimization of quantum entanglement principle is not part of the Standard Model. In the Standard Model the four parameters of the CKM matrix and the four parameters of the PMNS matrix are simply experimentally determined physical constants whose particular values have no explanation. So, this paper goes beyond what the Standard Model sets forth.
I would also argue that all three of the papers linked in this post are not just "numerology" papers, as they suggest a plausible physical mechanism or theoretical principal by which the values of the SM physical constants in question can be determined.
To our knowledge, this is the first time the differing CKM and PMNS structures have arisen from a common mechanism that does not invoke symmetries or symmetry breaking.
Jesse Thaler, Sokratis Trifinopoulos, "Flavor Patterns of Fundamental Particles from Quantum Entanglement?" arXiv:2410.23343 (October 30, 2024).The Cabibbo-Kobayashi-Maskawa (CKM) matrix, which controls flavor mixing between the three generations of quark fermions, is a key input to the Standard Model of particle physics. In this paper, we identify a surprising connection between quantum entanglement and the degree of quark mixing. Focusing on a specific limit of 2→2 quark scattering mediated by electroweak bosons, we find that the quantum entanglement generated by scattering is minimized when the CKM matrix is almost (but not exactly) diagonal, in qualitative agreement with observation.
With the discovery of neutrino masses and mixings, additional angles are needed to parametrize the Pontecorvo-Maki-Nakagawa-Sakata (PMNS) matrix in the lepton sector. Applying the same logic, we find that quantum entanglement is minimized when the PMNS matrix features two large angles and a smaller one, again in qualitative agreement with observation, plus a hint for suppressed CP violation.
We speculate on the (unlikely but tantalizing) possibility that minimization of quantum entanglement might be a fundamental principle that determines particle physics input parameters.
References 12-26 are from 2012 to 2024.Entanglement is a core phenomenon in quantum mechanics, where measurement outcomes are correlated beyond classical expectations. In particle physics, entanglement is so ubiquitous that we often take it for granted, but every neutral pion decay to two photons (π0 → γγ) is effectively a mini Einstein–Podolsky–Rosen experiment. In the context of SM scattering processes, though, the study and quantification of entanglement in its own right has only begun relatively recently [12–26]. In terms of predicting particle properties from entanglement, the first paper we are aware of is Ref. [27] which showed that maximizing helicity entanglement yields a reason but every neutral pion decay to two photons (π0 → γγ) is effectively a mini Einstein–Podolsky–Rosen experiment. In the context of SM scattering processes, though, the study and quantification of entanglement in its own right has only begun relatively recently [12–26]. In terms of predicting particle properties from entanglement, the first paper we are aware of is Ref. [27] which showed that maximizing helicity entanglement yields a reasonable prediction for the Weinberg angle θW, which controls the mixing between electroweak bosons.
A somewhat similar prior analysis that is not cited is Alexandre Alves, Alex G. Dias, Roberto da Silva, "Maximum Entropy Principle and the Higgs boson mass" (2015) (cited 42 times) whose abstract states:We happened to notice that in the limit where we neglect photon exchange, the exact valueθmin C =13◦ is recovered. However, we do not have a good reason on quantum field theoretic grounds to neglect the photon contribution. Because of the shallow entanglement minimum in Fig.2a, a 10% increase in the charged current process over the neutral-current one would be enough to accomplish this shift, which is roughly of the expected size for higher-order corrections.
A successful connection between Higgs boson decays and the Maximum Entropy Principle is presented. Based on the information theory inference approach we determine the Higgs boson mass as MH = 125.04 ± 0.25 GeV, a value fully compatible to the LHC measurement.
This is straightforwardly obtained by taking the Higgs boson branching ratios as the target probability distributions of the inference, without any extra assumptions beyond the Standard Model. Yet, the principle can be a powerful tool in the construction of any model affecting the Higgs sector. We give, as an example, the case where the Higgs boson has an extra invisible decay channel within a Higgs portal model.
