I Are There Two Suns? Exploring the Phenomenon of Sun Dogs
The discussion centers on the phenomenon of 'sun dogs' and related atmospheric optics, specifically the '22° halo' and possibly the '46° halo' or 'supralateral arc.' These effects occur due to sunlight reflecting off ice crystals in the atmosphere, creating secondary rings around the sun. Participants suggest consulting Wikipedia for detailed explanations and images of these phenomena. The conversation emphasizes that these optical effects are the most likely explanations for the appearance of what may seem like two suns. Understanding these atmospheric conditions can clarify the observed visual effects.
Fastmamon
TL;DR
Good morning, afternoon or evening, in the morning I encountered the phenomenon of the images where there seem to be two suns and a rainbow joined by two solar rings, the "main" sun has two rings, the secondary one had a very very faint one that the camera did not capture, please could you explain to me why the phenomenon occurs, thank you :).
Looks like 'sun dogs' with the '22° halo'. Maybe the '46° halo' or the 'supralateral arc' as well, seeing how there is a secondary ring. They're all, in general, the effect of sunlight being reflected off of ice crystals in the atmosphere.
Wikipedia has articles on those terms, with pictures and some more detailed explanation given. Have a look there and see if your question is answered to your satisfaction. Also worth checking are the other phenomena in the 'see also' sections of those articles, but I think the ones already mentioned are the most likely culprits.
Likes Fastmamon and berkeman
Thank you very much, just what I was looking for.
I'm setting up an analog power supply. I have the transformer bridge and filter capacitors so far. The transformer puts out 30 volts. I am currently using two parallel power transistors and a variable resistor to set the output. It also has a meter to monitor voltage. The question is this. How do I set up a single transistor to remove whats left of the ripple after the filter capacitors. It has to vary along with the control transistors to be constant in its ripple removing. The bases of the...
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 51 ·
9K
