Physical Interpretation of Frame Field
  • Context: Undergrad
  • Thread starter Thread starter cianfa72
The discussion centers on the physical interpretation of frame fields in the context of Fermi-Walker transport. It emphasizes that each observer's ruler defines a worldtube, with the local orthogonal spacelike hypersurface at an event intersecting this worldtube to determine the spacelike direction the ruler points. The conversation highlights the importance of tangent vectors and their relationship to spacelike directions, particularly in curved spacetime scenarios. A rigorous understanding requires acknowledging the distinction between tangent vectors and displacements in spacetime.
  • Understanding of Fermi-Walker transport
  • Familiarity with spacetime curvature concepts
  • Knowledge of tangent vectors and their properties
  • Basic principles of general relativity
  • Study the mathematical foundations of Fermi-Walker transport in Minkowski spacetime
  • Explore the implications of spacetime curvature on geodesics
  • Learn about the relationship between tangent vectors and directional derivatives
  • Investigate the role of orthogonality in defining spacelike directions in tangent spaces
Physicists, mathematicians, and students of general relativity who are interested in the geometric interpretation of spacetime and the mathematical formalism of frame fields and Fermi-Walker transport.
  • #31
cianfa72 said:
maybe I wasn't very clear in post #22.
Not just not very clear, but apparently confused about what you are trying to talk about. See below.
cianfa72 said:
In the general case (not geodesic curve) for both parallel and FW transport we need to know the curve and the vectors involved in the transport only at the point P from which the transport is carried out.
Yes. Which means that the key point you gave in post #22, about the solution being a first-order differential equation and therefore unique, does not apply to the general case. It only applies to the particular case of parallel transport along a geodesic.
So why did you even bother mentioning the first-order differential equation solution property, if you were interested in the general case? That property doesn't even hold for parallel transport in the general case, let alone FW transport.
In other words, based on what you're saying now, your post #22, and the entire subthread based on it, was wasting both your and my time.
  • #32
No. Given any curve C, a point P on it and a vector V at P one can solve the first-order differential equation for the parallel transport of V along C from P.
  • #33
If you know the curve C, yes.
But if all you know is the vector V at point P, the "exponentiation" operation you referred to earlier in the thread gives you the geodesic through P with tangent V at P. It doesn't give you any other curve. And your "ruler" construction depends on using the unique geodesic through P with tangent V, not any other curve.
So now I'm not clear about exactly what properties of a frame field you are asking about.
  • #34
Yes, of course.
I'm not asking about specific properties of frame field. I'm asking about the simple case of FW transport of a set of vectors (one timelike and three spacelike mutually orthogonal) from point P along a known curve C where the timelike vector is the tangent vector of the curve C at point P.
  • #35
cianfa72 said:
Yes, of course.
So, FW transport along any curve will preserve all of these properties. Parallel transport will only preserve them along a geodesic. For an arbitrary curve, parallel transport will preserve mutual orthogonality, but the timelike vector will no longer be tangent to the curve.
  • #36
Ok, indeed. My point was to stress the notion of parallel and FW transport: assign a curve C, a point P on it and a vector V at P (i.e. an element of the tangent space at P). Then the parallel or FW transport of V along C from P is well-defined.
Lie dragging is a different matter since it requires two vector fields X and Y defined on an open region (there isn't the notion of Lie dragging a vector along a curve). Btw, according to this video, even the notion of Lie dragging of a curve C (which we can think of as the integral curve of some suitable vector field X) along the flow of a vector field Y is well-defined.
  • #37
Do you think the above actually makes sense ?
  • #38
If you can Lie drag a vector field, how to Lie drag the integral curves of that vector field should be obvious.
  • #39
Just to be clear: take a timelike congruence in spacetime. Fix an event/point on each of them and take three spacelike vectors (in the tangent space at that point) that are mutually orthogonal each other and to the (timelike) tangent vector to the congruence's worldline passing through that point.
Now the FW transport process applied to the above vectors defines a frame field. By its very definition such a frame field's vectors turn out to be FW transported along the timelike congruence.
  • #40
Yes, all this is true and well known. Is there a question you have about this topic that hasn't been addressed yet?
  • #41
No, thanks for your time !
  • #42
You're welcome!
  • · Replies 57 ·
  • · Replies 16 ·
  • · Replies 158 ·
  • · Replies 0 ·
