Air compressor pump HP requirement?
  • Thread starter Thread starter Ryoko
The discussion revolves around the horsepower (HP) requirements for an air compressor pump, particularly after a replacement with a new unit. Participants explore issues related to motor specifications, pump performance, and operational challenges, including overheating and capacity considerations.
  • Experimental/applied
  • One participant notes that the new pump requires 5HP and 1050RPM, but the existing motor struggles to drive it, leading to overheating issues.
  • Another participant suggests that the 5HP rating on the motor may be overstated, proposing that the actual output could be around 3.7HP due to efficiency losses and voltage discrepancies.
  • Concerns are raised about the accuracy of motor specifications and the potential for manufacturers to misrepresent capabilities, particularly regarding service factors.
  • Questions are posed about the capacity of the old pump compared to the new one, and whether the original pump had an unloading valve that the replacement lacks.
  • Participants discuss the importance of cooling the compressed air and the need to adjust outlet pressure settings for under-rated motors.
  • Suggestions are made to implement a timer to manage the motor's operation and prevent overheating, allowing for cooling periods between runs.
  • One participant expresses confusion over the size of the air reservoir tank and its applications, while another clarifies its use for larger tasks like sandblasting and air tools.
Participants express various viewpoints regarding the motor's capability and the pump's requirements, with no consensus reached on the best approach to resolve the overheating issue or the adequacy of the motor's specifications.
Participants highlight potential limitations in the motor's performance due to voltage differences and efficiency assumptions, as well as the need for further information on the specifications of the old pump.
This discussion may be of interest to individuals dealing with air compressor systems, particularly those considering pump replacements or troubleshooting motor performance issues.
Ryoko
I replaced the pump on my air compressor with a Harbor Freight unit. The new pump says it requires 1050RPM and 5HP to drive it. The compressor has a 5HP motor which is supposed to be rated for continuous duty according to its spec plate. But it's unable to drive the new pump for more than a few minutes without tripping the overheat breaker on the motor. This is leading me to believe the pump is drawing more than 5HP. I've tried reducing the drive pulley size so the pump is now running around 800 RPM. But it still wants to trip the overheat breaker. The old pump had no issues until it croaked. So I'm wondering what's going on. Should the pump be undersized vs the motor to run reliably?
The 5 HP spec on your old motor is quite likely false. If the motor has a spec for continuous amperage draw that will give you an idea of what it actually is.
I think you're right. I looked up the specs again on the motor and it says 230v @ 15A and claims to be 5HP. The power specs work out to 4.6HP. So they rounded up. But that also assumed 100% efficiency. Since this is an induction motor, I'm guessing the actual HP is around 80% of the ideal figure or 3.7HP. This may well explain why the motor is struggling. As an added handicap, the line voltage is 220V rather than 230V which is probably contributing to the problem. So I guess I need to de-rate the motor accordingly and resize the pump.
They have creative ways of lying about the spec. Maybe the service factor is significantly reduced. This effectively says it will start a load typically suited for a 5 HP motor and run it for a short time. This is basically what you have experienced. When it's sold as a package the user is happy. It pumps and doesn't trip on overload. The company will say that you have modified it by replacing the pump so tough luck.
My shop compressor is a very old Quincy pump with a rusted out tank. The rusted out tank simply serves as the mount for the pump and motor. There is 200 gallon tank along side that I pump into. It's slow because I had a spare 3 HP motor to use in place of the 5 that came on it so the pump is slowed down so the motor can take it.
What was the capacity of the old pump in cubic feet of free air per minute?
How does that compare with the replacement?
Did the original pump have an unloading valve in the head, does the replacement pump have the same? Or is the motor turning off when the set pressure is reached?
Consider also the immediate cooling of the compressed air. The outlet from the pump will be hot air, which should be cooled at the head, before it enters the reservoir. Cooling the pump head will lower the peak pressure reached during compression.
The outlet pressure setting on the system, or the pump RPM and capacity, should be reduced for an under-rated motor.
I don't know the old pump's specs. It was extremely noisy. The unloading valve is built into the pressure switch. I already have a radiator on the pump outlet which works quite well.
200 Gal air resivoir tank is big .... I don't know what you use this for , most aplications only require short bursts of use (tyre pressure in garage etc), so compressor is only on for a short time... you could just leave things as they are , the overheat breaker is protecting from damage ... If the breaker requires manual reset this might be annoying , in which case install a timer which switches off before the breaker does .... so the timer is constantly switching on for 1 minute , off for 10 minutes (to allow cooling) this will let the compressor run only if tank pressure is low .... timer circuitry $5 ..... switching a 50A AC Solid State Relay $5
Or, you could pay attention to which poster is posting what.
  • Haha
LOL, that confused me too. I had to use a Search on the thread to figure out where he got the 200 gallon number from. :smile:
Just out of curiosity, though, why such a huge compressed air storage tank?
Very large tires, some sandblasting now and then, air tools, etc.
  • · Replies 19 ·
  • · Replies 33 ·
9K
  • · Replies 16 ·
11K
