- 38,098
- 10,654
I posted this in one of the math technical forum sections a few weeks ago, but didn't get much in the way of responses. In hopes of getting more involvement, I thought I would give it another shot here in General Discussion.
Here goes:
I've showed this trick to my 8-year-old grandson (who had a little help from his grandmother). The trick absolutely blew his mind, so much so that he drew several hearts on the paper he was using. I also showed it to my grandniece, who also loved it. I'm confident that she will show this trick to her friends at school.
Here goes:
- Write down a 3-digit positive integer. The only restriction is that the first and third digits should be different.
- Reverse the digits of the number you started with. (If the first number were, say 340, the new number would be 43.) Edit: if you end up with a 2-digit number, write this number with a leading 0.
- Subtract the smaller of the two numbers from the larger.
For example, if you started with 340, the new number would be 43. Subtracting results in 340 - 43 = 297. - Now take the number you ended up with (297 in the example above) and reverse its digits.
- Add the new number (792 in this example) to the number you ended with in step 3. If your arithmetic is correct, you'll always end up with exactly the same number. What number do you get?
