What causes knots and stress when untwisting ropes?
The discussion centers on the phenomenon of torsional stress and knot formation when untwisting ropes, drawing parallels to the role of topoisomerases in DNA replication. Torsional stress arises from the unwinding of coiled strands, leading to the development of supercoils and knots that hinder further uncoiling. The original twist in the rope is often in the opposite direction from the larger twist, contributing to the complexity of the untwisting process. Understanding these mechanics is crucial for both practical applications in rope handling and theoretical insights in molecular biology.
  • Understanding of torsional stress in physical materials
  • Familiarity with the concept of supercoiling in DNA
  • Knowledge of topoisomerases and their function in DNA replication
  • Basic principles of knot theory and its applications
  • Research the mechanics of torsional stress in materials science
  • Study the role of topoisomerases in molecular biology, specifically in DNA replication
  • Explore knot theory and its relevance to physical and biological systems
  • Investigate practical techniques for untwisting ropes without causing knots
This discussion is beneficial for physicists, biologists, material scientists, and anyone involved in practical applications of rope handling or studying molecular structures.
Aurelius120
[Mentor Note -- thread moved from the schoolwork forums to GD as it seems like a more general question]
Homework Statement::
Topoisomerases help in relieving strain in the DNA ahead of the replication fork caused by the untwisting of the double helix (Topoisomerases are enzymes that participate in the over winding or underwinding of DNA).
The strain is same as caused when two ropes twisted around each other are untwisted from both ends.
Relevant Equations:: NA
As shown in the image the ropes develop supercoils on being unwound.
The knots caused due to untwisting develops tension enough to make it impossible to uncoil the rope further.
My question is :
What causes such unwanted stress(called torisonal stress maybe) and these knots?
Why does it happen only with coiled strands of rope?
All research has failed at providing the right solution to this problem(or even an incentive)
I would guess that in untwisting the rope you are adding twist to the individual strands. I bet it doesn't happen if you comb it, i.e. allow the individual strands to twist freely.
It looks to me like the original twist in the rope is in the opposite direction from the larger twist shown.
I don't know why I am coming back here now, after aeons. But can you explain it a bit simpler.
Twisted fibre type ropes usually have three smaller twines (fibres twisted together) combined by twisting in the opposite direction - the smaller twines are initially overtwisted whilst under tension so that they provide a counter force that will wind the three together.
The finished rope has a balance of torsion between the twisting of fibres within each twine one way and the twisting of the three twines in the opposite direction.
Separate those twines and you unbalance the combined torsion that hold the rope together - you will be returning overtwining to the individual twines. When the torsion in one direction is stronger than the other (and it isn't held straight with strong tension) the individual twines will act a bit like what DNA does and coil around itself.
Yes, I agree with #4. An ordinary rope often has three strands, which are the bunches of fibres, and which are twisted around each other. The lay of the rope is the direction of twisting. If the strands are themselves twisted one way and are then twisted around each other the opposite way this called regular lay and is the usual one seen. If they go the same way it is called Lang's lay. Lang's lay will not self lock and will tend to come undone.
If DNA is made of strands that are not initially twisted, then when the strands are twisted round each other they will each acquire a twist in the same direction as the lay. This is "Lang's lay". Then if the strands are taken apart without allowing untwisting, they will each, if not kept under tension, coil around themselves forming a side shoot.
Is there a diagram or book or something that can show how the forces/stress balance everything and stay in place? Or get knotted when untwisted? (in a rope)
Also since DNA is only made up to two strands, unlike ropes where each strand is made of smaller fibers(twisted in the same/opposite direction as the strands)
Why will there be any supercoiling?
Not sure, but it does seem like Lang's lay is used primarily in wire ropes rather than fibre ropes. I think fibre ropes would be inclined to unravel that way, without the opposing winding to sustain it, whereas metal ropes will retain their winding.
