FLRW metric challenged, Einstein-Euler equations as alternative?
7 replies · 2K views
nomadreid
TL;DR
An article (source given) presents an alternative to the FLRW metric. Is my short rough summary of it (given in the main text) correct?
The question concerns the article "The instability of critical and underdense Friedmann spacetimes at the Big Bang as an alternative to dark energy" by Alexander, Vogler & Temple in Volume 482, Issue 2338 (May 2026) of the Proceedings of the Royal Society A, found in the link:
https://royalsocietypublishing.org/...20/The-instability-of-critical-and-underdense
Its merits are beyond my ability to judge, but as the journal is respectable, I am presuming that it contains no glaring faults. I also presume that it has not had time to make a major impact.
My question is whether my limited understanding of the content is valid, roughly:
The FLRW metric is highly sensitive to small perturbations, hence not a proper explanation of the expansion of the universe. However, one can derive the expansion from the Einstein-Euler equations, and do away with the necessity of the cosmological constant. If one gives up the FLRW metric, then one perhaps does not need the assumption of isotropy.
Corrections are welcome. Thank you.
Yes, that would be the case. The general idea, that deviations from the idealized FLRW solutions might be enough to account for observations without having to add a positive cosmological constant to the model, is not new; it's been around for quite some time, and we've had previous PF threads on other papers along these lines. This particular suggestion, however, appears to be new, so there might not be much that can be said about it at this point.
Reply
"If one gives up the FLRW metric, then one perhaps does not need the assumption of isotropy."
I haven't read the paper but would comment on the above statement^
If you say "the assumption of isotropy" I assume you mean "isotropy around every point" because isotropy *around us* is an observation not an assumption.
The FLRW metric arises precisely because of the assumption of everywhere isotropy. If we assume the universe looks the same in every direction at every point then we get the FLRW metric (people often also think we need to assume homogeneity but one can show that this is a consequence of everywhere isotropy). This is a purely geometric result, not depending on properties of the stress energy tensor except for that symmetry. So if you get rid of FLRW, you are rather *forced* to give up everywhere isotropy. Which usually means you give up the copernican principle (i.e. you say some other observers might not see isotropy) since, again, we see the universe as isotropic (to good approximation at least).
There are some technical ways you can avoid this -- some kind of global non simply connected topology for example (FLRW makes some global assumptions).
Reply
Interesting point, but I'm not sure this is the only possibility.
What about the Buchert averaging stuff? If I understand it correctly, the averaged Einstein equations on an inhomogeneous space don't reduce to FLRW, they get extra terms. So in principle you could have a geometry that's not FLRW anywhere locally, but still looks isotropic when you average over large enough scales. Whether the effect is big enough to matter cosmologically is debated (Green & Wald say no), but the mathematical possibility seems to be there.
I guess the key distinction is: pointwise isotropy everywhere (which forces FLRW, as you say) vs. statistical isotropy of the inhomogeneities, the second is weaker but might be all we actually observe.
Am I wrong on this?
Am I wrong on this?
Are you referring to the following?
https://inspirehep.net/literature/803660
No, I was thinking of Buchert's original paper (gr-qc/9906015). I might be oversimplifying things though, I'm not an expert on this.
Reply
gr-qc/9906015
Thank you; I have downloaded it from arXiv.
Reply
The universe is certainly not strictly isotropic. Even around us, the cmb has fluctuations. My statement was about the mathematics and geometry assuming isotropy (around every point).
Perhaps I was being pedantic. :)
Reply
