SpaceX starts operational Starship launches
  • Thread starter mfb
  • Featured
26 replies · 8K views · last reply
TL;DR
SpaceX plans to launch flight 14 no earlier than September 22. It will enter a circular orbit and deploy Starlink satellites.
Based on air traffic coordination
Edit: Also as FAA advisory now
SpaceX should release a flight plan soon but we can expect a ~250-350 km circular orbit with a booster splashdown near the launch site. It will then deploy Starlink v3 satellites which were made specifically for Starship. Some of them were already tested briefly on the previous suborbital flight.
After some yet unknown time, but almost certainly under 24 hours, it will do a deorbit burn and reenter for a splashdown. Potential target sites are the Indian Ocean as before, the Pacific near Hawaii, the Gulf of Mexico near the launch site (overflying the US and potentially Mexico), and some strips in the northern and southern Pacific.
It is unknown whether SpaceX will try to keep this ship intact on splashdown, intentionally crash it harder, or just leave it up to chance. We don't know why flight 14 is not trying to catch the ship, there must be something SpaceX needs to work on. We can expect ship catch attempts once they are happy with everything. More reentries will help.
Personally I don't expect a return to the Gulf until they go for a catch attempt. You have all the additional risk from a reentry over populated places without the benefit of a catch attempt. The ship would be much closer to the engineers for inspection, of course.
Assuming nothing goes wrong, flight 15 could follow in under a month. The ship and booster are already assembled and being tested. We might see about one flight per month until ship reuse increases that.
Edit: Moved to no earlier than September 22.
SpaceX posted it on their website
Still planned for September 22.
275 km orbit for about 10 hours, with a splashdown in the southern Pacific. It will deploy 26 Starlink satellites (~45 tonnes).
The flight will reuse two heat shield tiles from the previous mission.
SpaceX has been gradually increasing the payload they carry as they get better data on ship performance. The most efficient trajectory would do an orbit insertion after half an orbit (~45 min) instead of 25 min. The steeper ascent with an earlier orbit insertion burn is likely a safety measure, staying away from orbit and controlling the reentry corridor if the orbit insertion doesn't work for whatever reason.
Edit: Some more explanation by SpaceX (this link will stop working eventually, but it should work for a few weeks)
The initial ascent trajectory matches what they have flown so far. They'll have three earlier reentry options: Directly (no orbit circularization) in the Indian ocean, after a bit under one revolution (north Pacific), and one orbit before the planned deorbit burn (south Pacific).
Not sure if it's just me, but I keep hearing " Space Sex". Intriguing.
  • Agree
  • Haha
I think I knew what Musk was doing when he named that company. Weird guy. Who knows what his intentions were when he named SpaceX. I hear the same when the name is pronounced. Never liked the guy. At least reusable rockets are a thing now.
3 hours and 15 minutes until the launch window opens.
SpaceX coverage will start here in ~2:40
NASASpaceflight coverage is running
Every orbital flight in history had at least one stage or tank that was discarded in flight - left to crash into the ocean, burn up on reentry, or remain in space. This one will be the first exception, with both booster and ship being controlled until splashdown (or at least that's the plan).
Good splashdown of the booster, even though it lost one or two engines in the middle ring.
The upper stage lost a vacuum engine towards the end of the burn. This means they spent a bit more propellant on ascent to compensate. Not clear yet if they still go to orbit that way.
Edit: No circularization burn. Too unclear what went wrong with that engine and if it could affect other engines. This mission will be another suborbital flight going to the Indian Ocean.
They made progress on the booster, so maybe that will be caught next flight. Some chance they go for a ship capture on flight 15, too, assuming reentry will be smooth.
Starship is in a circular orbit!
They identified the issue with the vacuum engine and determined that it won't affect the rest of the mission.
Edit: Payload deployment is underway.
Edit: Payload deployment completed.
Starship will return after 3 hours
Not clear why. They spent a bit more propellant on ascent, deorbiting earlier reduces boiloff in orbit, maybe that is linked. Deorbit burn should be in ~30 minutes from now.
They have contact with all 26 satellites.
Should be the heaviest object ever to reach orbit in a single mission. It's even heavier than Mir and Tiangong. Only the ISS is a heavier man-made object in space and that was assembled with many flights.
Yeah, that's the normal outcome. The ship is designed to be caught by the launch tower. For testing they simulate that landing by hovering over the ocean. The ship then cuts its engine, hits the water and falls over. Usually that leads to an explosion. The previous flight had the ship survive, which was unexpected.
That was the default plan, but with options to return earlier. They chose one of these options. We don't know why, but some link to the upper stage engine failure is plausible.
It still did all the interesting parts. Staying in orbit for 8 hours vs. 2 hours isn't that different in terms of what you can learn from it.
full resolution of first image
Starlink satellite looking back at Starship after deployment:
Booster landing (look for the shockwave!):
The early reentries had tons of particles falling off the vehicle - you can see them as bright sparks racing across the screen. Step by step they have reduced that rate. This reentry looked like the smoothest one so far. You just have the glow of the compressed and heated atmosphere, and that's it. This looks great for reusability.
The deployed Starlink satellites have the bandwidth equivalent of 10 Starlink launches on Falcon 9. Increasing the payload to 100 tonnes will grow that to a factor 20. That means just one Starship launch per month can easily outperform the effective deployment rate Falcon 9 reached from Florida.
Edit: Starship in front of the Sun. You can see the sound:
Musk said the engine failure of flight 14 was just a software glitch.
SpaceX is aiming at November 8 for flight 15 (only called "flight 15") and December 10 for flight 16 (called "Starlink 30-1").
Flight 15 will try to catch both booster and ship. It looks like it will not carry a payload to keep the interior of the ship as simple and predictable as possible for the first catch. If successful, it would be the first orbital flight that recovers all its hardware.
Based on the mission name, flight 16 should deploy Starlink satellites. If 15 catches the booster and/or ship, I expect 16 to try to repeat that, this time with the Starlink dispenser installed.
Starship flight 15 is scheduled for Friday, November 13, 22:45 UTC (16:45 local time in Texas).
SpaceX wants to catch both stages, making this the first orbital rocket launch in history that doesn't discard anything. The ship is planned to land after 14 orbits or 22 hours in space, this means it'll reenter southbound over northern Mexico and the southern US. As before, if SpaceX isn't confident in a successful reentry they can deorbit earlier and splash down in the Pacific.
It will also carry and deploy 26 Starlink satellites similar to the previous flight.
Edit: News by SpaceX with more detail about the reentry maneuver and some animations.
The Booster was diverted to an ocean splashdown, SpaceX didn't say why.
Flawless ascent by the ship and successful payload deployment, they are in contact with all 26 satellites.
The ship just passed the checkpoint for a South Pacific deorbit (which would have limited the mission to ~8 hours). The next checkpoint will only come ~21 hours after launch: Deorbit 20 min early and splash down north of Hawaii or return to the launch site. Assuming it's still in a good condition, it will do a deorbit burn ~21:30 into the flight and land ~22:30 after launch.
Similar to the booster, the ship flies a trajectory that ends up in the ocean, and only diverts to the landing site if everything is still ready for a catch.
Booster didn't have enough propellant margins for a safe catch. The next flight will do stage separation a second earlier.
The decision where to deorbit should be made in around 35 minutes. It's either a splashdown north of Hawaii (deorbit burn in a bit over an hour) or back to the launch site (deorbit burn in 1 hour 30 minutes). So far things look good for a catch. If something bad happens between these two times then SpaceX can abort and aim for a splashdown near Hawaii next orbit. If something bad happens after the deorbit burn then it can splash down in the Gulf of Mexico.
Approximate reentry corridor:
Map of North America and the Pacific from Google Earth showing a yellow-outlined range of notional RTLS abort areas and a red-outlined middle area stretching from the Pacific toward the Gulf of Mexico.
Not sure about the visibility in daylight. I tried to find daylight reentry sightings of the Space Shuttle but found nothing. It was easily visible during twilight but even there I found almost no video material.
Edit: Poll done, go for return to launch site
Edit2: Deorbit burn done, it will return to launch site.
Photo of a tall steel launch tower beside a dark, scorched rocket upper stage standing on the coast, with grey overcast sky and surf behind it.
The reentry was also the cleanest ever, I didn't see anything burn up.
We'll see if this ship flies again. I expect at least a few components to fly again, for the whole ship it's less clear. SpaceX will primarily use it to inspect the status of a flown ship.
This will become normal - most future Starship flights will look like this (plus a caught booster).
One heat shield tile in the middle of the booster was lost on ascent. This led to some damage in its vicinity and red stains below it:
Musk says the ship could probably fly again with a few weeks of refurbishment. We are unlikely to find out - newer ships have tons of changes that need to be tested. Maybe we get a static fire test of the flown ship.
Edit: Capture videos from both flaps - looks like the booster contacted the chopsticks in the final descent and damaged the surface of both a bit. Nothing that can't be fixed and improved for future flights.
