DaveC426913
2025 Award
- 24,696
- 9,090
- TL;DR
- Want to make sure I understand this correctly: escape velocity is "only" necessary because we have limited fuel supply, ensuring we have to get to orbital velocity before it runs out.
I'm working on a story, and I want to ensure I have the basics straight. I'm not looking for any speculation, just facts.
It is necessary to achieve escape velocity - not because we can't escape without achieving it - but because we need to achieve it before we run out of fuel, or we will just fall back.
Currently, we need to achieve orbital velocity before we run out of fuel. But if we ease the constraint on fuel limits, we don't need to worry about escape velocity (effectively, though it's still there).
And it's directly tied to our current technology: chemical propulsion, which has an upper limit on specific impulse (somewhere in the high hundreds of seconds), and involves the rocket equation to constrain our options.
By hypothetical contrast, say we manage to get a working fission or fusion drive. They can have a SI of thousands or tens of thousands or even more (depending on who you ask). This means we can get to orbit and beyond long before running out of fuel.
The upshot here is that, with an engine more efficient than chemical (albeit still propulsion-based) one could choose to lift off from Earth and rise at, say, a flat 5000mph or something. In fact, you could fly all the way to the Moon's orbit at 5000mph, if you chose. Granted, you might still not achieve escape velocity so that, if you waited long enough, you would eventually fall back (an object falling from 250,000 miles from stopped would take on the order of 3 days). But since you have plenty of fuel, you are free to jst turn on your drive and go whereever you want from there.
Am I correct?
Imagine a drive that could only do 1g (so the astronauts would experience 2g on lift off). Without a fuel constraint, it could simply accelerate to 5000mph and throttle back till it just balances Earth's g-pull, and spend the rest of the trip out of the system at 5000mph.
(The above is not any actual scenario, I just want to confirm my assumption that "escape velocity" - in a practical fashion - is a consequence of limited fuel.)
Am I correct?
