Line_112
- 59
- 4
- TL;DR
- Complex computer procedures are used to extract signals of the desired frequency from general radio noise, which likely makes such extraction unreliable. Could this factor be the cause of distorted radio signal data?
I recently read a paper by scientists about the results of a search for radio signals from extraterrestrial civilizations using the Chinese FAST telescope. After carefully screening out candidates, they were left with one particularly suspicious signal, emanating from the direction of the star K2-155. However, when they searched for similar signals at similar frequencies in data from the same observation day, they found similar signals (three, I think). The similarity was only in polarization direction; in other respects, they differed significantly. Those signals looked more like interference, leading the researchers to conclude that this signal could also be of terrestrial origin.
However, they were unable to link these signals to any external radio source, but they hypothesized that they could be instrumental interference.
This is where I'm unclear. The telescope itself shouldn't emit anything, as its purpose is to receive, not send, signals. The process of extracting narrowband signals from the general radio noise, as I've read, is a rather complex procedure performed by a supercomputer, which divides the general noise into millions of narrow frequency bands. The different polarization channels are obviously processed separately. Could it be that the absence (or lack of power) of the signals they found in another polarization channel was not due to their being highly polarized, but rather because the computer failed to identify them in the other channel or incorrectly estimated their power (underestimated)?
Link to the study: https://iopscience.iop.org/article/10.3847/1538-3881/ae8f34
